cayenne transmission oil change
Old Sep 22, 2009 | 03:30 PM
lovethesport's Avatar
lovethesport is infamous around these parts
has any done this on a 2005 cayenne s
i am thinking of doing this vehicle has 65k miles on it---
do you know part nos for the filter and the pan gasket----also how many ltrs of oil is needed
any other tips/information is greatly appreciated
thank you
Old Sep 22, 2009 | 06:33 PM
tonga3's Avatar
tonga3 is infamous around these parts
I'm pretty sure the fluid does not have to be changed until 250000 km's.
Old Sep 22, 2009 | 07:53 PM
c,mon--there is no fluid in the world that will last that long
Old Sep 23, 2009 | 04:28 AM
tonga3's Avatar
Additional maintenance
Note!
• The engine oil and oil filter must be changed every
10,000 km (6,000 mls) in vehicles which are
operated in countries where leaded fuel is used.
Additional maintenance, replacing spark plugs
Þ Page 58 'Replacing spark plugs' OK
Replace spark plugs in Cayenne Turbo every 60,000 km/40,000 mls or every 4 years
Replace spark plugs in Cayenne S every 90,000 km/60,000 mls or every 4 years
Additional maintenance every 120,000 km/80,000 mls
Additional maintenance every 120,000 km/80,000 mls OK
Air cleaner: replace filter element
Þ Page 66 'Replacing air cleaner element'
Additional maintenance every 240,000 km/160,000 mls or every 16 years
Additional maintenance every 240,000 km/160,000 mls or every 16 years OK
All-wheel final drive: replace oil
Þ Page 114 'Changing oil for all-wheel final drive'
Rear final drive: replace oil
Þ Page 104 'Changing oil for rear final drive'
Transfer box: replace oil
Þ Page 99 'Changing oil for transfer box'
Manual transmission: replace oil
Tiptronic transmission: change ATF
Þ Page 90 'Replacing ATF'
and ATF filter
Þ Page 107 'Removing and installing ATF filter'
Additional
Old Sep 23, 2009 | 05:20 AM
ONE234's Avatar
ONE234 has much to be proud ofONE234 has much to be proud ofONE234 has much to be proud ofONE234 has much to be proud ofONE234 has much to be proud ofONE234 has much to be proud ofONE234 has much to be proud ofONE234 has much to be proud of
CHANGE YOUR FLUID.....
its the best thing you can do to your car after engine maintinance.
just use the porsche fluid as its a very specific type.
your car will run smoother and the changes will be seemless.
i was so supprised at the difference.
dont forget the filter and gasket also.
easy job with a ramp.
Old Jun 12, 2011 | 10:40 AM
andrewgarland's Avatar
andrewgarland is infamous around these parts
I had the dealer change my 04 cayenne S transmission fluid/filter for routine maintanance at 42k miles. I got it back and hard shifting! The trans was flawless prior to thier fluid change, and now "BANG!" into second gear once a day. Sometimes 5th to 6th on a lesser scale. Reverse too, but im normally not accelerating much in reverse so its not as noticable.
Any ideas? too much fluid, not enough fluid, other?
Any help?
The dealer says to drive it around and let it "learn."
The shift/BANG is severe on occasion and will lead to failure if not addressed.
Old Jun 12, 2011 | 11:21 AM
taddyangle's Avatar
taddyangle is infamous around these parts
I recetly noticed this too with my 5S. It occurs periodically when i drive aggresive and between 5 to 6. I am not sure what to do either. I was thinking about getting fluid changed.
Old Jun 12, 2011 | 04:14 PM
mine was not doing it at all- worked flawless - until i did the routine maintanance (trans fluid change.) Im wondering is it low or too full on fluid or did they "re-map" the trans computer to make it do this?
Old Jun 12, 2011 | 04:18 PM
deilenberger's Avatar
deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !
I believe that was a rather common complaint with the '04 models and there was a range of VIN#'s where a service bulletin was issued on replacing the transmission valve assembly body when this happened.
It also would be worth checking the fluid level, perhaps low fluid level might cause this if it allowed slippage before the clutches engaged on gear changes.
I would be all over the dealer on it since it didn't do it before, and they fixed it until it broke..
Old Dec 3, 2020 | 05:51 PM
Tad Simmons's Avatar
Tad Simmons is infamous around these parts
How did it last?
This was a long time ago but I am looking for some long term performance info. There’s some talk of changing transmission fluid being actually bad for the transmission and that it will cause problems on a high mileage trans. What’s your experience?
Old Dec 27, 2020 | 09:06 PM
Tecchie's Avatar
Tecchie is infamous around these parts
Guys, it's a known issue with the VALVE body. The transmission is built by AISIN. I get a 5-4 bang under heavy acceleration and a few other annoying things but otherwise fine. They were manufactured with inferior pistons for starters and they wear out the bores/pistons. The easiest fix seems to replace the valve body and you're only out a little over a grand in parts until you send your core unit back to where you bought it from..
It seems you can source one from here, I need to call them. I have questions.
RevMax Converters
I've also attached a transmission file for ya'll to read.
09D.pdf - Google Drive
pshep138
Sep 1, 2015 09:45 AM
BLKonBLK911C4S
NorCal
Aug 29, 2015 03:20 AM
LiquidElephant
Aug 27, 2015 06:17 PM
gulf gt
Aug 27, 2015 10:27 AM
00aston
Aug 27, 2015 12:01 AM
