Just Picked Up A 2010 GTS...
Old Dec 9, 2009 | 07:18 AM
RojoGTS's Avatar
RojoGTS is infamous around these parts
Black on Black 6-speed, Already did clear markers, hardwired V_1 and some other small mods, Looking into the Fabspeed bypass pipes next.
My GTS doesnt have Sat-radio or the aux input, what are my options ? the only thing I came across was the mobridge setup any others?
Old Dec 9, 2009 | 09:26 AM
jyupitt1's Avatar
jyupitt1 has a reputation beyond reputejyupitt1 has a reputation beyond reputejyupitt1 has a reputation beyond reputejyupitt1 has a reputation beyond reputejyupitt1 has a reputation beyond reputejyupitt1 has a reputation beyond reputejyupitt1 has a reputation beyond reputejyupitt1 has a reputation beyond reputejyupitt1 has a reputation beyond reputejyupitt1 has a reputation beyond reputejyupitt1 has a reputation beyond repute
Congrat. Could you please share a picture of location /instruction on hard wiring the v1? Did you ask your dealer to do it? I have a 09 Cayenne S, and not sure whats the best place to hardwire the V1
Thanks,
John
Old Dec 9, 2009 | 09:29 AM
Griza's Avatar
Griza has much to be proud ofGriza has much to be proud ofGriza has much to be proud ofGriza has much to be proud ofGriza has much to be proud ofGriza has much to be proud ofGriza has much to be proud ofGriza has much to be proud of
Can you retro fit the oem satellite module and aux input? That would be your best bet if possible.
Old Dec 9, 2009 | 01:39 PM
Cpa4S's Avatar
Cpa4S is a splendid one to beholdCpa4S is a splendid one to beholdCpa4S is a splendid one to beholdCpa4S is a splendid one to beholdCpa4S is a splendid one to beholdCpa4S is a splendid one to beholdCpa4S is a splendid one to behold
nice machine - 6 speed manual i take it?
Old Dec 9, 2009 | 02:34 PM
RojoGTS's Avatar
Cpa4S- Yes 6 speed only way to play....
Griza- The dealer said I cant upgrade but im not sure...
Old Dec 9, 2009 | 02:48 PM
RojoGTS's Avatar
Thanks,
John
You need the hardwire kit from Valentine and you can use the fuse box behide the drivers side dash end cap.
Old Dec 9, 2009 | 06:36 PM
Cpa4S's Avatar
i still keep waffling on the cat by pass
Old Dec 9, 2009 | 06:39 PM
lumber's Avatar
lumber is infamous around these parts
I just put a fabspeed bypass on my new gts...I would highly recommend hearing/driving one in person before you do it.
Nothing against fabspeed, its a quality piece, its just not a clean exhaust note...verrry rrraspy, and not on a good way. (and i like exhaust noise)
Old Dec 9, 2009 | 06:42 PM
lumber's Avatar
...and i have a 6 speed, fwiw
Old Dec 10, 2009 | 05:22 AM
Griza's Avatar
Dealers typically don't know sh*t. It could probably be done. BTW, are you Rojo Collision/Auto body?
Old Dec 10, 2009 | 08:16 AM
Rec Racing's Avatar
Rec Racing has a spectacular aura aboutRec Racing has a spectacular aura about
I have a 2009 GTS six speed. Can you post a picture of where you located the V-1? Thanks. Also when I took delivery the dealer assured me that the XM module would be released shortly to allow an easy plug in installation. The module is still not out according to the good folks at Suncoast. Man I want XM!
Old Dec 10, 2009 | 10:15 AM
RojoGTS's Avatar
Yes Im one the owners of Rojo Collision
Old Dec 10, 2009 | 12:35 PM
RojoGTS's Avatar
I will post a pic of the V1 as soon as I get a chance...
Old Dec 10, 2009 | 01:49 PM
jyupitt1's Avatar
I will post a pic of the V1 as soon as I get a change...
Thanks. did you do this yourself? or at a dealer? I usually do my own V1 hardwiring but am afraid it would trigger a warning message on the cayenne...
Old Dec 10, 2009 | 02:41 PM
RojoGTS's Avatar
Its pretty simple remove the dash board end cap on the drivers side. Gives you access to all the fuses check for one the is only on with the ACC postion and your good to go.
