I want to find where this stereo plug leads to...
Looks like a standard RCA to audio mini-jack cable... should work with any audio device using a headphone jack or mini-jack line out. If using the headphone output however use low volume at first since it is a line-in connection most likely to the nav unit. If the volume is not high enough using the nav unit you can then adjust the headphone volume at the audio unit itself to compensate. Just a guess on my part though!
COBB Tuning
03-29-2016 09:26 PM
COBB Tuning
09-09-2015 09:13 PM
