Removing Interior Trim
Old Jun 24, 2010 | 02:06 PM
SeattleBum's Avatar
SeattleBum has much to be proud ofSeattleBum has much to be proud ofSeattleBum has much to be proud ofSeattleBum has much to be proud ofSeattleBum has much to be proud ofSeattleBum has much to be proud ofSeattleBum has much to be proud ofSeattleBum has much to be proud ofSeattleBum has much to be proud ofSeattleBum has much to be proud of
Any advice on as to carefully remove the interior trim pieces around the cabin? I recently bought some of that carbon fiber look-alike vinyl others have been raving about and I wanted to try it on a few interior pieces. Do you need a special tool? Are there ideal places to wedge and pop off the pieces? Thanks in advance!
Old Jun 25, 2010 | 01:55 PM
mlc.design's Avatar
mlc.design is infamous around these parts
Use a plastic prier or use a flat blade screwdriver with electrical tape an gently pull
Old Jun 25, 2010 | 02:07 PM
SeattleBum's Avatar
Thanks!
Old Jun 25, 2010 | 03:38 PM
111GTS's Avatar
111GTS is infamous around these parts
@SeattleBum Please post pics on the DIY. I am thinking of doing the same on the interior of my gts
Old Jun 25, 2010 | 03:55 PM
bbywu's Avatar
http://www.suncoastparts.com/product...97tT_Accessint
Works well...a little flex at times, but sometimes that's a good thing.
Old Sep 27, 2011 | 09:26 AM
GOB's Avatar
GOB
GOB has much to be proud ofGOB has much to be proud ofGOB has much to be proud ofGOB has much to be proud ofGOB has much to be proud ofGOB has much to be proud ofGOB has much to be proud ofGOB has much to be proud ofGOB has much to be proud ofGOB has much to be proud of
I had a few trim pieces removed by the local dealer and they used a white plastic tool to remove the pieces. I was told (could not confirm) that the tool was made out of some sort of wax so it "gives" a bit and it will actually scrape pieces off it (did look like white wax shards). It had the Porsche script on it.
Old Sep 27, 2011 | 11:36 AM
deilenberger's Avatar
deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !
That set is frequently on sale at Harbor Freight for less then $3... just a FWIW (have a set hanging in my garage..)
RallyBird
Oct 7, 2015 01:20 PM
away
Sep 4, 2015 12:30 PM
inamjetdriver
Aug 31, 2015 08:01 PM
pogeybait
Aug 28, 2015 04:47 PM
