Found a solution to having no spare tire!!
Old Sep 14, 2010 | 09:47 AM
Cole's Avatar
Cole is just really niceCole is just really niceCole is just really niceCole is just really nice
Wink Found a solution to having no spare tire!!
Makes getting in the back tricky but you won't be stranded
Old Sep 14, 2010 | 12:40 PM
str8blst's Avatar
str8blst Is a GOD !str8blst Is a GOD !str8blst Is a GOD !str8blst Is a GOD !str8blst Is a GOD !str8blst Is a GOD !str8blst Is a GOD !str8blst Is a GOD !str8blst Is a GOD !str8blst Is a GOD !str8blst Is a GOD !
I love your avatar BTW... 2.7T engine no?
Nice pic ....
Old Sep 14, 2010 | 01:05 PM
Cole's Avatar
Nice pic ....
Thanks!
Yes, 2.7T from my 2000 Audi S4. We had it out for a tech session and made the "Poster Shots" for 3Zero3 Motorsports here in Wheatridge, Co.
....and the random "in the car, in front of my house" shots
Old Sep 28, 2010 | 01:02 PM
CA Bimmer's Avatar
CA Bimmer is infamous around these parts
What year Cayennes dont have a spare, my 08 does.
Old Sep 28, 2010 | 01:23 PM
2muchtime's Avatar
2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute
no spare in my CTT 04'
Old Sep 28, 2010 | 09:39 PM
Cole's Avatar
Dual battery with a Bose sub. No room for a spare.
They come with fix-a-flat and an air pump.
Old Sep 29, 2010 | 02:53 PM
norsecarnut's Avatar
norsecarnut is infamous around these parts
and some people don't call that tiny thing a "spare". I don't anyway.
Old Sep 29, 2010 | 03:43 PM
Which model Cayenne do you have? I thought all of them did come with the silly deflated skinny spare.
I was considering an Allroad but the Touareg or Cayenne compliment what we have better I think. That photo showing the motorcycle must be approaching the tongue weight rating though.
Old Sep 29, 2010 | 03:58 PM
Cole's Avatar
I have an 04 Turbo. The dual battery option puts the second battery in the spare tire compartment. Then it puts a larger Bose Sub over it. If you don't have the dual battery you get a smaller Bose sub that the inflatable spare fits over.
Tounge weight is 617 lbs if I remember correctly. A KLR650 is 337lbs dry. The hitch carrier is aluminum and I would bet is 60-70lbs total or less.
So you are talking a total weight less than 450lbs on a 617lb tonge capacity.
Old Sep 29, 2010 | 04:07 PM
that's pretty good tongue weight rating.
In case anyone else wonders this too, what purpose does that "dual battery" serve? I have an LR3 set up for extensive off road trips with a 2nd battery which itself is 2x larger than most suvs standard battery. It's used for running a freezer, lights, air tank/compressor, and in general keeping you able to start up after a week of that stuff.
Relative to this thread, have many people brought in the Porsche full size tire carrier?
Old Sep 29, 2010 | 04:40 PM
Cole's Avatar
I'm a long time wheeler. Even spent 10 years writing for an online magazine building rigs, etc. All part of the reason I like the Cayenne.
The Cayenne is set up like most wheelers would run a dual battery set up with an isolator. One batter runs all the accessories and the other is only for starting the car.
I'm seriously considering adding a multi-mount winch and some lights that I already have laying here from past projects.
As for the no spare issue. Here is a quick camera phone pic of the spare tire well for you. Might help. Fwiw the Cayenne also has OBA to fill the tires which is a nice built in.
Old Sep 30, 2010 | 11:06 AM
so are you saying there was an "option" in 2004 turbos to get a bigger SUB which then also brought the other battery along with it? It would make sense as those drain a lot if the vehicle isn't running.
Do you have any idea what the option code is or what it was called so I can see in my search? Of course a photo of the tire area from anyone selling would make it obvious what's built in there.
Old Sep 30, 2010 | 11:17 AM
Can you point me to any more informational threads or sites on real off road experience in these?
I was aware of the on board air as it was also in the Touareg we had. It's a tiny tank but still a nice feature.
In your "opinion" if you were having to decide between what's out there on the used market, which way would you go? :
2008-09 (any model) with PDCC, mainly for it's ability to disconnect the sway bars offroad but also being better on road.
OR
04-06 Turbo with "off road tech package" allowing rear diff lock + sway bar disconnect on demand in low range via button beside gearing slider.
Other variations in the above:
1- 06 Turbo S with the off road tech option (would simply need to swap front brakes with a Turbo owner to allow 18" wheels)
2- 08-09 GTS with PDCC, maybe even a 6 spd....(would pretty much have to forget about finding a GTS with offroad tech)
3- Transsyberia without either PDCC or off road tech package (not sure if Trans had the option for either off road tech or PDCC) (I realize the Transsyberia is essentially an S with the GTS engine)
(Being that new 2011 don't have low range anymore and cost too much anyway.)
Old Sep 30, 2010 | 12:27 PM
Cole's Avatar
I don't think the sub itself is any different. The enclosure is bigger to accomodate the bigger battery. The second battery is the option, not the different sub.
As for which one I would choose. That is a tough question.
It is REALLY hard to find older Cayennes with the Off Road Tech package. I just don't think that many were ordered.
I figured I would do some light wheeling with mine so I went with the "most bang for the buck" option that would not leave me feeing too bad when I scratched it.
Near as I can figure it would be cheaper to buy a Turbo and add some performance upgrades than to buy a Turbo S. There simply is not that much that is actually different between them (intercoolers, software, tie rods, control arm bushing, lowering module program, front brakes)
A non-turbo *might* be more reliable in the dust and dirt. But way less fun on the paved surfaces.
Old Sep 30, 2010 | 12:30 PM
Cole's Avatar
....oh and a pic from my most recent build and "suspension testing" day. WE had just installed an AEV suspension and were getting ready to write a review.
To bad Porsche can't make one flex like this and handle like a Porsche.
