Check Direction Indicators ? But...They Work
Old Oct 17, 2010 | 08:56 PM
RobsCountach's Avatar
RobsCountach is infamous around these parts
Hey Folks,
Anybody else get this message; However, the front & rear both work. Also, the 'clicker/indicator' is double-speed, which is typical with a bad bulb changing the resistance, but again... no lights out.
Its intermittent - of course.
Old Oct 17, 2010 | 10:26 PM
skydiver's Avatar
skydiver is infamous around these parts
Originally Posted by RobsCountach
Hey Folks,
I have had this happen. Turns out the connector on the back of the tail light had a bit of corroding on it. Cleaned it with some sand paper and contact spray, replaced both side bulbs just in case and never had the problem since...
Old Oct 27, 2010 | 04:43 PM
cmoore1's Avatar
cmoore1 is infamous around these parts
My 06S did the same-"check direction indicators", always the left side & double speed indicator-but every time I checked both front and back lights were working ok. Finally the front light didn't work so assumed it was the bulb-changed the bulb-still didn't work. Found the culprit to be corosion on the tabs where the bulb holder connects to the housing. A little fine sandpaper on the contact tabs and it's been working fine for months.
Old Oct 27, 2010 | 07:18 PM
gr8ful's Avatar
gr8ful is a name known to allgr8ful is a name known to allgr8ful is a name known to allgr8ful is a name known to allgr8ful is a name known to allgr8ful is a name known to all
Similarly, just removing and repalcing the bulbs cured the problematic contact. I guess the newer LEDs eliminate this.
Old Oct 28, 2010 | 05:15 AM
FastHackem's Avatar
FastHackem has much to be proud ofFastHackem has much to be proud ofFastHackem has much to be proud ofFastHackem has much to be proud ofFastHackem has much to be proud ofFastHackem has much to be proud ofFastHackem has much to be proud ofFastHackem has much to be proud ofFastHackem has much to be proud of
Not necessarily, I doubt that the new Porsches have all LED lights. I don't know for sure, but from what I have seen, most manufacturers that have turned to LED lighting still use halogen bulbs in some of the lenses thus they are prone to corrode and produce the "check whatever indicator" light.
Old Oct 28, 2010 | 06:23 AM
Bigbuzuki's Avatar
Bigbuzuki is infamous around these parts
The new LED lights also have their own unique sort of problems when they get a little older.
Old Oct 28, 2010 | 06:42 AM
FastHackem's Avatar
Yeah they do actually. I have had problems with LED 3rd brake lights on two cars now. Eventually it seems the solder joints from the LED to the circuit board they are soldered to begin to age and break thus causing intermittent operation and strobing. Looks bad and its expensive because often you have to replace the whole assembly unless your experienced and can repair those sort of things.
Old Nov 27, 2014 | 10:06 AM
Zuffenhausen955's Avatar
Zuffenhausen955 is infamous around these partsZuffenhausen955 is infamous around these parts
Mine started doing it too.....but, only when the left flasher is running more than 30 seconds. How hard is it to check front/rear connectors?
Aug 21, 2015 06:34 AM
Aug 19, 2015 06:35 PM
Nissan GTR
Aug 19, 2015 02:11 PM
Yotam Refael
Cayenne
Aug 18, 2015 03:03 PM
