Strange heat AC issue
Old Dec 20, 2010 | 07:51 AM
Pepper's Avatar
Pepper is infamous around these parts
Unhappy Strange heat AC issue
I have a 2004 Cayenne S, 68kmi, when I put the heat on I have heat on the drivers side and cold air on the passenger side. It does not matter what I set the passsenger side to, ie, HI heat, recirculate, 78, 85, it blows cold, so I just turn it off. I recall I get the reverse effect in the summer, Ice cold for the drivers side when I want it cold (in other words, drivers side always works), but still hot on the passengers.
Is there a reset or reprogram I can try?
Anyone have any clues as to what this could be before I spend my lifes savings at the stealership?
Old Dec 20, 2010 | 09:44 AM
RisingAgainst's Avatar
RisingAgainst is infamous around these parts
I have the same car, same mileage and had a similar issue about 6k miles ago, but it was dealer fixed for 1.5 hours labor, no parts.
My issue was slightly different, I had my climate control come on automatically and blow opposite temps throughout my vehicle. when I wanted cold, it was hot on both sides, and when I wanted hot it was "warm" on both sides.
Don't know if its the same issue as yours, but I hope it helps some.
Old Dec 20, 2010 | 01:49 PM
Pepper's Avatar
I did want to mention sometimes after 15 minutes or so the passenger side begins to work normally. Once it works, it works the rest of that ride, but each time I get back in, I never know if the passenger side is going to blow cold in the winter or HOT in the summer even when the AC is on full blast. Also I have the digital thermostat controls in the backconsole as well and yes right rear is off like passengers.
I'm pretty mechanically inclined, so if anyone knows a DIY please let me know. Thanks!
Old Feb 1, 2012 | 12:38 AM
racerja's Avatar
racerja is infamous around these parts
Did anyone figure out what the solve was? Are there some adjustments that the dealer was able to make?
I have a similar quirky issue - drivers always blows hot, passengers side seems to work fine.
dkim12
Jan 21, 2021 04:00 PM
alwaysbored786
Apr 19, 2016 05:51 AM
gulf gt
Aug 27, 2015 10:27 AM
'02996ttx50
Aug 26, 2015 05:56 AM
