Modifying order.
My guess would be no, since your build date is so close. Check with your dealer. I can't quite remember, but I believe my order was locked a good 45-60 days before my build date, as I tried adding to mine as well.
Thank you! Man... why all wheels are so expensive?... For 21" Sport Edition wheels in Silver it costs $4875 when I order with vehicle and $6927.80 purchase by own...
Does anyone know where can I purchase used wheels? (modulare or other 21" wheels?)
The reason they are less expensive when ordering with the vehicle is your are adding the upgraded wheels but deleting the stock wheels. Essentially by adding later you have purchased 8 wheels instead of 4. Adding to the expense by purchasing later, you have to buy larger tires also. You could use the stock smaller wheels for snow tires and sell the stock tires.
I am trying this myself to add an option...it probably is slim, the dealer needs to call Germany tomorrow and determine if it can be changed as I am pretty far up in build queue. It is worth a try and to ask dealer. Good luck.
my start build date was approx. Feb 17th though I have not yet seen this in writing. I got a change put through on 1/27 but the car was locked the next day; I too wanted more wheel.
You may squeak it by, but is questionable.
I've decided to to be happy with the ordered 19's as i realize that i hit back dirt roads more than most and that I'll probably throw snows on from time to time. And I'll run on the one inch lowered AS so looks should be ok if not spectacular.
My wife is fed up with too many wheels in the garage so i am taking the chickens way out.... and saving a few pennies in the meantime. if anyone sees a glitch with this thinking i would appreciate a heads up.
best of luck
best of luck
best of luck
best of luck
So true. Married 20 years. My theory is, "Happy Wife. Happy Life"
Oct 2, 2015 02:23 PM
ModBargains.com
996 Turbo Vendor Classifieds
Oct 1, 2015 11:48 AM
