Went to CTT today and.......
Old Apr 28, 2011 | 09:35 AM
pepper09tt's Avatar
pepper09tt is a splendid one to beholdpepper09tt is a splendid one to beholdpepper09tt is a splendid one to beholdpepper09tt is a splendid one to beholdpepper09tt is a splendid one to beholdpepper09tt is a splendid one to beholdpepper09tt is a splendid one to behold
Thanks for the detailed explanation ozr
Old Apr 28, 2011 | 01:35 PM
slw23's Avatar
slw23 is infamous around these parts
ozr- tough to argue with ya, as it certainly sounds like you know what you're talking about!
However, my settings don't entirely get stored to the key. It does retain the seat settings (I valet quite often and notice when the seat is adjusted), but the radio presets/settings don't always stick. Case in point, I tried to add a new radio station at least 3 times, only to realize I kept forgetting to store to the memory buttons to make it stay. Occasionally, even my own last seat settings won't stick with the key. Not sure if this is a problem or not, but like zspeed, I just hit the seat memory button and all is well again.
Thanks for the detail.
Old Apr 28, 2011 | 01:39 PM
zzzspeed's Avatar
zzzspeed Is a GOD !zzzspeed Is a GOD !zzzspeed Is a GOD !zzzspeed Is a GOD !zzzspeed Is a GOD !zzzspeed Is a GOD !zzzspeed Is a GOD !zzzspeed Is a GOD !zzzspeed Is a GOD !zzzspeed Is a GOD !zzzspeed Is a GOD !
ozr,
Thanks, I will mention it when I bring it in for service. The steering column is starting to make a little clicking sound once in a while.
Old Apr 28, 2011 | 09:49 PM
Charcharius's Avatar
Charcharius is infamous around these parts
Hi All,
I completely agree on the control module explanation, and I don't believe this issue is related to low battery voltage. I noticed that my '11 CS wasn't storing seat positions, radio settings, vehicle menu stuff, etc. They would be wiped nearly every time I started 'er up, but not every time.
Here are the service comments from my dealer -- the problem is now completely fixed, and no new parts were required. HTH.
Cause: Control unit for seat memory incorrect basic setting and coding.
Correction: Attempted to clear fault memory. Fault would not clear. Started guided fault finding. Per test plan checked function of fore aft seat adjustment. Found working normally, was about to replace control unit per test step two. Tried resetting to factory setting and recoded control unit manually, then ran normalization procedure on seat. After procedure completed, fault would clear and seat memory functions were available and working as specified.
BonitaBeast
Cayenne 955/957
11
Oct 16, 2015 06:14 PM
ModBargains
Ferrari Vendor Classifieds
Oct 13, 2015 03:47 PM
ModBargains
Oct 13, 2015 03:45 PM
vchris
Cayenne Turbo
Sep 11, 2015 02:52 PM
Compukidd
Sep 11, 2015 07:56 AM
