Rough / Slow Start
Old May 18, 2011 | 08:01 AM
dafink44's Avatar
dafink44 is infamous around these parts
Rough / Slow Start
I have a 2005 CTT, lately I have noticed it needs to turn a few times in order to start up. Has anyone else noticed this cranking issue when performing a cold start? Anything to be concerned about? I have 2 months left on my warranty and want to get it checked out before it's up.
Thanks!
Old May 19, 2011 | 12:44 PM
dafink44's Avatar
Damn crickets....?!?!?
Old May 20, 2011 | 07:20 AM
lbredefe's Avatar
lbredefe is infamous around these parts
My CS sometimes starts a bit rough, and then immediately thereafter I am having an issue with coolant temp sensor, not sure if it is feeding bad info to the computer for fuel air mixture ratio or not. with what porsche service costs, I would definitely definitely get it checked out. and while your at it, get an extended warranty. I bought a non CPO and after dealer warranty ran out, I have taken a 4k bath so far!
(06 CS - CSM / big brake package)
Old May 20, 2011 | 02:03 PM
deilenberger's Avatar
deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !
I'm not gonna repeat the whole thing here - but see: http://www.renntech.org/forums/topic...ing-any-ideas/
If the symptom is - difficult starting and what feels like a lean start when it does start, with no check engine light - chances are - you have a pressure loss to the fuel rail. The diagnostics are a bit complicated since Porsche hasn't documented the fuel system very well, and there are apparently some undocumented check valves that can cause this problem.
Since you're in Hoboken - if you're running down to the shore this weekend (I'm in Spring Lake) - I could hook my fuel pressure gauge up and confirm if this is the problem. Takes about 5 minutes to do. Ping me if interested. I'll be off on my bike on Sunday, so tomorrow is a better time.
At least then you'd have something concrete to suggest to the dealer.
The original selling dealer on my truck was useless "Could not reproduce problem, no codes.." - Princeton Porsche understood immediately that there WAS a problem, and worked on it until they found the fix. Kudos to the guys at Princeton!
adnanm3
Nov 22, 2023 02:43 AM
PV=nRT.
Sep 9, 2022 06:06 PM
Rguy
Apr 12, 2020 11:11 PM
ModBargains
Maserati Vendor Classifieds
Oct 13, 2015 03:46 PM
GSP
Sep 9, 2015 05:31 AM
