need help gear shift install
Old May 4, 2012 | 04:23 PM
ferraristyle's Avatar
ferraristyle has a spectacular aura aboutferraristyle has a spectacular aura about
So I know to remove you put the car in drive or neutral and pull up.
I assume the reverse is true but my new shift **** as a little red round pulltab key in it. Wondering if it needs to be installed in a certain gear and do you pull the tab before or after the install.
Any help would be great. Plus I don't want to break my new cf shfter :-)
Old May 5, 2012 | 08:44 AM
vishal's Avatar
vishal is infamous around these parts
The new shifter will slide right on the shaft in neutral as well. Pull the red key out AFTER the **** is fully seated on the shaft.
MAcarbon
Mar 6, 2017 08:16 AM
orbelo
Aug 30, 2015 12:26 PM
MAcarbon
Aug 20, 2015 03:02 PM
MAcarbon
Aug 19, 2015 06:22 PM
MAcarbon
Aug 19, 2015 04:52 PM
