Switched to hawk hps from pads... Disappointed
Old May 9, 2012 | 03:28 PM
intheflesh's Avatar
intheflesh has a spectacular aura aboutintheflesh has a spectacular aura aboutintheflesh has a spectacular aura about
A while back a switched my front pads to hawk hps. I immediately noticed the difference from stock and was very disappointed. The car stops fine, but I felt like I was missing that initial 'bite'. I really have to press the brakes hard to get any stopping power.
I'm wondering if I made an installation error? I bedded the pads per the instructions. I had read a similar experience when switching to the HPS.
I'm looking for a new set of pads... I've heard recommendations from padgid, ebc, and Centric.
Not really sure which I'm going with. Hell I might even switch back to oem. The dust never really bothered me.
Old May 9, 2012 | 09:11 PM
Renaissance.Man's Avatar
Moderator
Renaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond repute
I just installed a fresh set of Hawk HPS pads on the wife's Audi a few weeks ago. I had to go through the bedding procedure twice to get it close to the OEM level of initial bite.
Even after the second bedding session, I noticed a similar effect that the initial bite is somewhat less - although much improved after the second session. I think this is a byproduct of the higher heat range of the pad compound. After several personal tests, empirical evidence would suggest that the Hawk HPS pads work much better than the OEM pads after heating them up. If you are a casual driver, then this may have less value to you.
The great news is that we were trying to reduce brake dust on her wheels and these pads improved in that area exponentially.
If you are not driving aggressively and didn't mind the brake dust, there is nothing wrong with the OEM pads. FWIW, Porsche OEM are Pagid pads.
Old May 10, 2012 | 05:56 AM
damon@tirerack's Avatar
Moderator
When you replaced the pads, did they go in against new or honed rotors? If not, you don't have fresh metal to bed in against, and it's likely your problem. If the iron is fresh, I would also recommend a second bed-in procedure. Read this please. Don't be afraid to get them hot. The HPS pad is our number one selling replacement pad and in general people are very pleased with them. Initial bite with these pads should be at least as good as OEM if bedded correctly.
damon@tirerack.com
877-522-8473 ext. 4643
574-287-2345 ext. 4643
Or use this link:
Old May 10, 2012 | 09:10 AM
strife_wy's Avatar
strife_wy has a spectacular aura aboutstrife_wy has a spectacular aura about
Initial bite on HPS Pads are going to be lower than stock when cold... it's pretty common feedback (I posted about this before as well). Once warm you won't miss a thing.
As mentioned above, you should also make sure that your pads are bedded properly, and that your rotors were at minimum resurfaced. This is pretty standard procedure when installing any new set of pads.
Old May 10, 2012 | 09:16 PM
porschespeeddemon's Avatar
porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !
I had the Hawk HPS ceramic pads with brand new R1 concepts drilled/slotted rotors. Found out on Loveland pass that no matter how hard I pressed the brake pedal, I had virtually NO stopping power. Was a bit un-nerving. Contacted Hawk(who were great to work with), sent me brand new pads, followed ALL bedding processes as before with the first set, per the instructions. Same result. And to top it off, they squeeled like no other brakes I've ever heard. 7mph or 77mph, didn't matter, they were awful. Tossed them all for Turbo S brakes with EBC reds.
Old May 12, 2012 | 03:50 PM
intheflesh's Avatar
Update:
When i installed the hawks originally, I did change the rotors at the same time. I had put close to 5k miles on the hawks.
Last night I put a set of pagid pads in the front to replace the hawks. The hawks were glazed over.
The difference with the pagids is night and day. Never going to buy the hawks again.
Old Apr 15, 2013 | 01:32 AM
Frutti_pig's Avatar
Frutti_pig is infamous around these parts
I'm thinking of using EBC discs with yellow stuff pads, thoughts or suggestions APPRECIATED!
Anyone else using this combo and happy?
Cheers
FP
Old Apr 15, 2013 | 08:26 AM
Moderator
Cheers
FP
I just switched to the EBC yellowstuff pads a couple of weeks ago. I know they are not autocross pads, but that did not stop me from using them when autocrossing. They are better than the stop padgid pads, but not as good as the Carbotech XP8 pads I was using before.
Considering that the pads are half the price and much easier to get, I think I will be using them again.
White991TT
Mar 8, 2016 06:01 AM
007 Vantage
Oct 8, 2015 08:35 PM
ECS Tuning - BMW
Oct 1, 2015 01:35 PM
ECS Tuning - BMW
Oct 1, 2015 01:29 PM
ECS Tuning - VW
Sep 28, 2015 03:19 PM
