"Brake Booster Faulty"
Old Jun 8, 2012 | 08:30 PM
bansasn's Avatar
bansasn is a name known to allbansasn is a name known to allbansasn is a name known to allbansasn is a name known to allbansasn is a name known to allbansasn is a name known to all
Anyone experience their "Brake Booster Faulty" warning? My sensor appears and than disappear. Even when I am driving on the fwy or the city the "Brake Booster Faulty" light up. When I turn the car off and on again everything is normal again. I took it to the dealer and they can't find anything wrong with the sensor or faulty codes that would cause the problem. My brake is fine when press. Not odd sounds or an any thing else. Any thoughts anyone?
Old Jun 12, 2012 | 11:25 AM
the head's Avatar
the head is a jewel in the roughthe head is a jewel in the roughthe head is a jewel in the roughthe head is a jewel in the rough
Vacuum leak most likely near the small pump on the passenger side, rear corner of the engine bay under the black plastic cover. Start it up and poke around in there and one of the hard plastic vacuum lines is most likely cracked. When it gets big enough the pump will run almost continuously to keep vacuum in the system and the warning light will just stay on.
Old Jun 12, 2012 | 08:46 PM
bansasn's Avatar
Thank you. I will look into it this weekend. I'll keep you posted. Do warranty covers this kind of problem?
Old Jun 13, 2012 | 02:48 AM
Cole's Avatar
Cole is just really niceCole is just really niceCole is just really niceCole is just really nice
Just wrap electrical tape around the hose and it will cure the issue. Seriously.
(It's vaccum, not a high pressure hose! It's a small known leak issue that is easily fixed with a touch of tape)
Old Jun 13, 2012 | 06:50 AM
the head's Avatar
Not sure if it does or not. My CPO warranty expired about a while ago.
And like Cole stated, tape works great. I cut the hose so the crack wouldn't propogate and leak again using rubber hose to make up for the part cut out.
Old Aug 4, 2013 | 02:10 PM
hadydaddy's Avatar
hadydaddy is infamous around these parts
as i was wrapping my cars booster vacuum hose noticed this broken hose , have taken close up pictures, and i think it should be mounted onto the air box. can anyone mention how important is it to go back into its place?
https://www.6speedonline.com/forums/...breather-9125/
Old Aug 7, 2013 | 08:38 AM
Jagman1's Avatar
Jagman1 is infamous around these parts
That is the air intake line for the air suspension compressor. So, is it critical? I'm not sure. It there so that only filtered air reaches the compressor. I'd just epoxy it in place and call it good. Otherwise if you replace the lower half of the air filter box that should do it.
Old Aug 7, 2013 | 12:28 PM
hadydaddy's Avatar
Could this be the reason for the chassis system faulty message displaying on my dash
Old Aug 9, 2013 | 07:07 AM
Jagman1's Avatar
The error message you're getting would not be caused by this air supply line. It's likely that something else is causing this issue. The most exposed parts of the air suspension (and those most likely to suffer damage) are the wheel sensors at all four corners. I'd start looking there and see if anything is amiss.
Old Feb 7, 2015 | 06:11 PM
TurboSOnly's Avatar
TurboSOnly is just really niceTurboSOnly is just really niceTurboSOnly is just really niceTurboSOnly is just really niceTurboSOnly is just really nice
If you get this error code it is likely a hose leak. Follow the line off the brake booster compressor. It's an easy fix. I had to remove my break booster to find it but that was 2 screws. I found it right after and used a pipe clamp and some rubber cement to fix the leak.
Old Feb 18, 2015 | 10:49 AM
ciaka's Avatar
ehmm, look up to see the post dates...lol.
I think they must have already figured something out between 2013 and 2015.
Old Feb 18, 2015 | 11:14 AM
TurboSOnly's Avatar
I posted that for future people who find this thread. That's what responsible repair forum guys do. Since you have 580 posts you probably know that.
Old Feb 18, 2015 | 04:42 PM
ciaka's Avatar
Someone grabbed decaf by mistake today in the morning.
I know. You know. No need to be talking like that. Turn that frown up side down.
Old Feb 18, 2015 | 05:32 PM
TurboSOnly's Avatar
No negative tone intended. You know text can sound different than it was meant. Its all good.
ModBargains
McLaren Vendor Classifieds
Oct 13, 2015 03:41 PM
ModBargains
Oct 13, 2015 03:40 PM
ECS Tuning - VW
Sep 2, 2015 09:03 AM
