New 06 TTS owner!
Old Sep 23, 2012 | 05:12 PM
Carbon6Nik's Avatar
Carbon6Nik is infamous around these parts
New 06 TTS owner!
Hey guys, so I recently picked up a CA TTS with 72k on the clock. It was a one owner vehicle and per the carfax:
08/30/2007 11,421-
Maintenance inspection completed Oil and filter changed Front brake pads and rotors replaced Tire pressure monitoring system checked Tail light bulb(s) replaced
04/30/2008 18,986-
Front brake pads replaced Rear brake pads replaced Recommended maintenance performed Brakes serviced Brake fluid flushed/changed
07/25/2008 22,973-
Maintenance inspection completed Brake pads replaced
12/05/2008 26,822-
Headlights serviced Tail light assembly replaced Engine/powertrain computer/module replaced Maintenance inspection completed Recommended maintenance performed
04/23/2009 32,550- Coolant Pipes???
Engine cleaned Intake manifold gasket replaced Maintenance inspection completed Cooling system checked Headlight bulb(s) replaced Headlights adjusted
09/09/2009 37,476-
Maintenance inspection completed Front brake pads and rotors replaced
03/10/2010 46,378-
Oil and filter changed Brake pads replaced Lamp assembly replaced Maintenance inspection completed
05/31/2011 No milage- previous service 5/17/11 64,118
Tire condition and pressure checked Maintenance inspection completed Steering/suspension checked Brakes serviced Engine/powertrain computer/module checked
All services done at Mckenna Motors Norwalk, CA.
Man this thing is a BEAST!!! This is my second Cayenne and got this to replace my 2010 SRT8 Grand Cherokee. Paid $36k which is high but the service records and one vehicle owner made me more willing to spend a few more. Options are pretty standard however has the SIM card GPS as well as the panoramic sunroof which I love having. Also included (real) Techart 22's with Nitto 555s!
It is missing the GPS DVD, the DVD map door, and the TPS sensors. Minor details.
First things first is the the 80k service interval, battery replacement, and new intake. Would love to put a set of GTS seats in the TTS but will probably just end up getting mine reupholstered. Also toying with doing a wrap... will see.
Also:
Anyone recommend NGK plugs, should I use a step colder??
Old Sep 23, 2012 | 05:35 PM
X5X's Avatar
X5X
X5X is infamous around these parts
Looks great! It that a real TTS?
Old Sep 23, 2012 | 05:40 PM
Porsche Jabs's Avatar
Porsche Jabs is infamous around these parts
Looks mean and nasty! Love it.
Old Sep 23, 2012 | 07:47 PM
Carbon6Nik's Avatar
Not sure what you mean by real, but yes per the VIN it is. Also, here is a link to all the dealer pics that were posted. Close to 40 pics!
http://www.texasimportsales.com/web/...photos/990876/
Old Sep 23, 2012 | 09:25 PM
russnyc's Avatar
russnyc is infamous around these parts
beautiful, congratulations
Old Sep 24, 2012 | 07:56 PM
Renaissance.Man's Avatar
Moderator
Renaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond repute
Pretty stealth! Now lower it
To answer you question, you should only put in 1 step colder plugs if you have upgraded the engine about 100-150 hp. Since it is pretty much stock, I would keep the same temp range.
On another note, the Jeep SRT8 has a really aggressive launch. Given its less than impressive highway performance, I am guessing it has much short gearing for stoplight runs. Inversely, the tall gearing on the CTT makes it a terror on the highway. Enjoy shocking people.
Old Sep 24, 2012 | 08:54 PM
GothamCayenne's Avatar
GothamCayenne is infamous around these partsGothamCayenne is infamous around these parts
This is exactly what I thought of the jeep when I drove, god it was fun from light to light but once it got going it was nothing special.
Old Sep 24, 2012 | 08:56 PM
Carbon6Nik, I am thinking of wrapping mine too. I have the all black everything look as well but I think a flat black wrap would really set it off. Although the flat black vinyl wrap thing has gotten way overplayed by every boy racer here in Boston, not sure if its the same where you are...
Old Sep 25, 2012 | 03:46 PM
Carbon6Nik's Avatar
Actually dont see many wraps here in the DC area, only on I have see was a matte brown/ grey on a GTS that looked stellar. I was thinking along the lines of lime green with black wheels and lime green calipers....
Old Sep 26, 2012 | 10:09 AM
Old Sep 28, 2012 | 03:08 AM
Carbon6Nik's Avatar
Hate to say, I like the color but seems to busy for me. I like the BMW for that reason, clean and simple. Might consider wrapping/painting all the window trim black, adding a light tent on the rear lights, side markers, and maybe paint the interior housing of the fogs black to set everything off.....
Old Sep 28, 2012 | 12:01 PM
s4treg's Avatar
s4treg is infamous around these parts
Start with getting the trim blacked out, it's not that much and will really change the entire look of the car.
(since this pic, I smoked the tailpipes too)
Old Sep 28, 2012 | 12:02 PM
s4treg's Avatar
Oh and congrats on the purchase! Wicked fast SUV's, and Kent's right...wait till you get out on the highways...your gonna shock a lot of people.
PV=nRT.
Sep 9, 2022 06:06 PM
Rguy
Apr 12, 2020 11:11 PM
Rockinc1
Sep 30, 2015 06:44 PM
manfred@loma_wheels
Sep 2, 2015 11:22 AM
