Battery for Porsche Cayenne 'S'
Subscribe
Oct 1, 2012 | 05:31 AM
Recently bought a 2009 Cayenne S, having the follwoing issues, your inputs may help find solution.
How can make sure that my battery is good? i have had few starting troubles, gauge shows slight above 12 when battery turned on, it goes further after starting the vehicle.
Is there any suitable aftermarket battery for Porshce? if yes, what is the capacity that i should look for?
There is also slight whining noise while taking the car out of parking and running in very slow speed (5-10kmph), is it from alternator?
Reply
Oct 3, 2012 | 10:11 PM
Quote: How can make sure that my battery is good? i have had few starting troubles, gauge shows slight above 12 when battery turned on, it goes further after starting the vehicle.
Battery load tester. You can buy one for under $40 USD or take it to a mechanic have them load test the battery. They can also load test the charging (alternator) system.
Quote: Is there any suitable aftermarket battery for Porshce? if yes, what is the capacity that i should look for?
The make/model of the car is irrelevant (unless lightweight lithium-ion batteries are used- see GT2RS). There are only a few main manufacturers of car batteries - they are then relabeled and distributed. I have always heard great things about Interstate and Optima batteries. I have used them too with really good results.
If you want other options besides OEM, just match CCA (cold cranking amps), terminal style, terminal positive and negative position and general size.
Quote: There is also slight whining noise while taking the car out of parking and running in very slow speed (5-10kmph), is it from alternator?
I doubt it. I have not heard of an alternator whining as a failing symptom. Why did you single out the alternator?
Reply
Oct 4, 2012 | 01:20 AM
Quote: I doubt it. I have not heard of an alternator whining as a failing symptom. Why did you single out the alternator?
Thanks for your input - i am planning to visit the Porsche garage in this weekend, and will have it checked....
with regards to Alternator whining noise - i have heard similiar sound from my old Mustag GT when its alternator was on the way out, so i thought its might be same.
What kind of battery they use on 09 Porsche Cayennes? is it maintenance free or something else?
Reply
Oct 4, 2012 | 08:30 AM
I picked up both (dual battery car)of my batteries for my CTT at Autozone. About $130 each. Way cheaper than the dealer and a super easy DIY.
Reply
Oct 4, 2012 | 12:03 PM
The whining noise could be your power steering pump. They just had to replace the one on my CTT because it was making way to much noise. If you have PDCC on the vehicle, the pump has to work very hard. The noise could be cold fluid and the pump making noise trying to push it until it warms up.
Reply
Sep 8, 2014 | 11:36 AM
I went to Advance Auto Parts West Palm Beach ...
and got a Autocraft platinum AGM #10210828 Model H8AGM
$188.99 36 month FREE replacement if any defects...No Q asked
This was a EXACT factory replacement, it fitted, was the top of the line battery over the gold model. The exact size as I took my battery in and even the plastic clamps were exact. The battery posts were oem size, there was a breather tube in the exact same spot.
This is 900 CCA and wound over the Pepper starter so fast I was amazed...this battery has some power wow!
I did the job myself in a hour...check out this guys youtube
Make sure you connect a trickle charge under the hood before you pull the old battery or all your settings/radio codes will be gone!
Anyways the clerk said this Batt will go 7 years...its a good one...
Reply
Sep 8, 2014 | 11:52 AM
Quote: I did the job myself in a hour...check out this guys youtube
Nice video find! A little overly verbose for my tastes, but definitely good nevertheless.
Reply
Sep 8, 2014 | 02:42 PM
+1 for the Advance Auto battery. I put one in the 996turbo and like what was mentioned it turns over like 500RPM !
They also clam they will install it for you, even on a Cayenne. 30min wait time.
Reply
Sep 12, 2014 | 08:46 PM
Yes my Pepper is winding over very fast!!!...it 'lights up' like a Varooom!...awesome battery!...my wife not afraid to drive it now with all the key turning easy on the first flick of a twist, now its a instant start! The exhaust sound explodes with the cats out
Reply
Sep 13, 2014 | 07:26 PM
We'll if you want to pay big bucks and have a top line battery check out total power batteries. Allot of off road race trucks use them and these are military grade used on the stealth fighters and bombers. Plus check out cranking amps verse your agm battery. Total power has about 1500 cranking amps vs the agm which is around 970
Reply
Dec 29, 2014 | 05:11 PM
FYI an alternative would be Interstate MT5-49/H8. It's also a AGM with 900cca and 1000ca.
Do not ever trust whoever try to sell you the Interstate MTP-49/H8 even it is listed on their store. That battery only has 730cca and is known to have starting problem after install.
Reply
Dec 29, 2014 | 10:57 PM
Total power racing batteries! The end.
Reply
Jan 18, 2015 | 01:35 PM
My Advance Battery is still running VERY strong...Very Happy!
Reply
Subscribe
