2005 CTT oil leak
Old Jan 20, 2013 | 11:00 PM
bansasn's Avatar
bansasn is a name known to allbansasn is a name known to allbansasn is a name known to allbansasn is a name known to allbansasn is a name known to allbansasn is a name known to all
2005 CTT oil leak
Hi guys,
Anyone know what is causing my oil leak here? I have an oil leak at the drain plug. Prior to my oil changed it also have the same leak. I changed the oil two months ago and also changed the oil drain plug washer. Thought that might stopped it. Now it still leaking. Could it be the drain bolt is bad? Hate to take it to the dealer anyone experience this? Do extended warranty cover this problem? Thanks in advance.
Old Jan 21, 2013 | 10:46 PM
VIPNiSS's Avatar
VIPNiSS is infamous around these parts
it could be the drain plug.. i have seen several other guys on here have the same issue and it was the plug itself causing it
Old Jan 22, 2013 | 07:33 AM
Dennis C's Avatar
Drain plug leaks after an oil change due to a cracked drain plug are quite common. The drain plug is made of aluminum and it can deform and crack quite easily if it is over tightened. Luckily, it's inexpensive to replace. I think it's about $15. Your dealer will have them in stock since this happens frequently.
Old Jan 22, 2013 | 10:11 PM
bansasn's Avatar
Thanks guys...I will change my drain plug on the next oil change. Til then I will have to keep an eye on the seapage. I have been refilling the oil every 350 miles. Make that two bottles.
BonitaBeast
Cayenne 955/957
11
Oct 16, 2015 06:14 PM
carbonjim996TT
Sep 20, 2015 08:14 AM
DLF
Cayenne Turbo
Sep 3, 2015 01:36 PM
ECS Tuning - VW
Sep 2, 2015 01:47 PM
ECS Tuning - VW
Sep 2, 2015 01:19 PM
