Cayenne Transfer Case Fluid Change DIY
Old Mar 30, 2013 | 10:46 PM
ciaka's Avatar
Here are steps to complete transfer case fluid change.
Used Red Line D4 fluid (about 16 bucks from ebay shipped)
Each pic is numbered in sequence of doing with step details.
Hope this helps someone here.
ID:	226319   Click image for larger version
ID:	226322   Click image for larger version
Old Mar 30, 2013 | 10:47 PM
ciaka's Avatar
cont'd...
ID:	226324   Click image for larger version
Old Mar 30, 2013 | 11:38 PM
stormy69's Avatar
stormy69 is infamous around these parts
ciaka, i havent looked into as i just picked up my c, how did you determine that d4 was the correct fluid?
nice write up btw, should make it a cinch for those less mechanically inclined...
Old Mar 31, 2013 | 09:54 AM
zzzx's Avatar
zzzx is infamous around these parts
thanks for sharing
very important as ciaka pointed out that loosing the fill screw first before draining. just in case the fill hole is stuck.
Old Mar 31, 2013 | 11:09 AM
ciaka's Avatar
Although several fluids can be used, all of which satsfy the Porsche requirements, i chose to go with a fluid chosen by anotber member (on here and renntech), who has gone into trouble of fluid comparison, and confifmed by others as well.
this product actually exceeds the needs but you can choose something else if you do not trust it. Thanks.
Old Mar 31, 2013 | 12:06 PM
cuemaster's Avatar
cuemaster Is a GOD !cuemaster Is a GOD !cuemaster Is a GOD !cuemaster Is a GOD !cuemaster Is a GOD !cuemaster Is a GOD !cuemaster Is a GOD !cuemaster Is a GOD !cuemaster Is a GOD !cuemaster Is a GOD !cuemaster Is a GOD !
nice write up, I've been thinking about doing this. thanks.
Old Mar 31, 2013 | 02:24 PM
stormy69's Avatar
i just wanted some background (trust but verify). Redline makes great products, i use them at times. Saves me the trouble of research
Old Mar 31, 2013 | 02:26 PM
stormy69's Avatar
one quart does the trick?
Old Mar 31, 2013 | 04:32 PM
ciaka's Avatar
Service manual calls for .75 Qt I believe, but since some is spilled due to fill process, you will use close to 1Qt. I used almost all.
Old Mar 31, 2013 | 05:15 PM
VIPNiSS's Avatar
VIPNiSS is infamous around these parts
always great to have members contribute DIY to save us all money to get more tires
great DIY!!
Old Mar 31, 2013 | 08:11 PM
ciaka's Avatar
Lol...and we all know we need money for more tires...these cayenne suckers devour them pretty quick.
Old Apr 1, 2013 | 02:36 PM
carreracup03's Avatar
carreracup03 is a jewel in the roughcarreracup03 is a jewel in the roughcarreracup03 is a jewel in the roughcarreracup03 is a jewel in the rough
I thought you guys might find this thread interesting .... albeit BMW website
http://forums.bimmerforums.com/forum...-redline-D4ATF
Old Apr 1, 2013 | 03:05 PM
Renaissance.Man's Avatar
Moderator
Renaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond repute
Nice DIY! What is the recommended interval for the transfer case oil change?
Old Apr 1, 2013 | 07:30 PM
ciaka's Avatar
I do not know the service interval for transfer case, but since it is easy and cheap to do, I will likely do this every couple years. Will do same for rear and front differentials too.
If someone knows actual service intervals for t.c, rear diff, frt diff, chime in please.
Old Apr 1, 2013 | 11:01 PM
stormy69's Avatar
t-case and manual trans arent even remotely in the same ballpark. I have used rl mtl in my esprit and 00 ws6. I wasnt impressed but it also was no worse than what i drained from either...
00aston
Aug 27, 2015 12:01 AM
Zero911
Aug 24, 2015 06:51 PM
Aug 20, 2015 12:17 PM
ECS Tuning - BMW
Aug 19, 2015 09:29 AM
Yotam Refael
Cayenne
Aug 18, 2015 03:03 PM
