Help with trailer wiring troubleshooting
Old Apr 24, 2013 | 08:06 PM
ciaka's Avatar
have 05CTT.
It has a hitch and wiring installed (I think from factory since it was not even used until I looked at it).
Wanted to use it, so unscrewed the little cover that covers the connector side of the wiring next to the hitch.
Was a 7 blade connection.
Went to autozone, bought the Hopking #426515 wiring kit (7 blade plus 4 straight connector).
The connector plugged right into the connection on the car once i removed the cover.
Friend brought a small trailer over. All lighting works on his car just fine.
When i plugged the wiring to my car, I saw an error on my cluster saying check the trailer tail lights.
When checking, the directional lights work (left, right, emergency).
The stop lights work fine when pressing brake.
The tail lights (ones that are supposed to be lit up when you turn on your headlights so other cars can see the trailer when driving), do not turn on.
Bought the little tester to test connection (little black plastic with LEDs), and it also says tail lights to indicate there is something wrong with them.
Any help will be appreciated.
Old Apr 24, 2013 | 09:28 PM
Renaissance.Man's Avatar
Moderator
Renaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond repute
Simple - you will need a 7-way to 4- pin converter that has built-in resisters for LED trailer lights. This is make the error message go away on the cluster. Something similar to this will work.
Old Apr 24, 2013 | 10:44 PM
ciaka's Avatar
TThis is the connector i bought.
Click here
Can you explain why i would need to buy a 7 pin to 4 pin connector even though the one i have already has a 4 pin built in, in addition to the 7 pin?
Everything works but tail lights when i turn headlights on (for night driving). Trying to understand reasoning. Thanks for help in advance.
The tail lights in trailer are not LEDs. They are regular incadescent bulbs, but i checked and all seem to be fine, even friend's truck hookup alloqs ail lights to work.
Old Apr 24, 2013 | 11:06 PM
cmoore1's Avatar
cmoore1 is infamous around these parts
I would look for a possible blown fuse. My 06 manual shows fuses for "towing attachment" in the right side of dashboard fuse box --fuses 1,3,5,41--all 15amp except 41 is 10 amp.
Old Apr 25, 2013 | 01:44 PM
ciaka's Avatar
checked the fuses and they are fine (ones you mentioned). any other ideas? Maybe replace the connector? can it be faulty right out of the factory?
Old Apr 26, 2013 | 10:03 PM
cmoore1's Avatar
I wouldn't really expect the connector--it's just a straight thru device--the wiring harness hooks up to the backside and the trailer plug hooks up to the front side. Possibly the control unit (P/N 955 618 040 10 -a $150 part from the dealer) is bad --it's mounted in the right side rear fenderwell--under the cd changer if you have one. Maybe it's time to bite the bullet and have the stealer diagnose the problem?
Old Apr 27, 2013 | 06:22 AM
ciaka's Avatar
Can anyone tell which of the four straight connections carries signal for tail lights? I will try to probe it to see if it is hot when headlights turn on. If yes, it will be something on trailer side. If i can find diagram of the 4 connections, it msy help
Old Apr 29, 2013 | 10:37 AM
cmoore1's Avatar
The standard pinout for a 4pin connector is:
Male pin=gnd next=tail next=left turn next=right turn
Old Apr 29, 2013 | 07:31 PM
stormy69's Avatar
stormy69 is infamous around these parts
ciaka, i bought the same adapter you did and have no issues on my 06. maybe there is a fault in the adapter you bought? i would check continuity on all the pins to verify that while you are out probing..
Old Apr 30, 2013 | 03:05 PM
Moderator
Forgot to add this factory-style adapter in my original post, instead of the option you chose:
Pollak 11-893P 7-Way Sealed RV OEM Socket
Old Apr 30, 2013 | 03:35 PM
stormy69's Avatar
crap, i didnt see those when i was hunting for something to use much cleaner than what ciaka and I have.
amazon prime $14 shipped
Pollak 11-893P 7-Way Sealed RV OEM Socket : Amazon.com : Automotive Pollak 11-893P 7-Way Sealed RV OEM Socket : Amazon.com : Automotive
Old Apr 30, 2013 | 03:43 PM
Moderator
Yeah, sorry, I will be putting up a few stickies here shortly on this subsection. I will make sure to include this as well.
FWIW, I have had corrosion issues (on previous vehicles) with the versions with the built-in 4 pin connectors on the side. This sealed connection is much more waterproof than a rubber boot. Not to mention, that I add a liberal does of di-electric grease to the internal pins as added insurance.
wrs
Nov 17, 2016 06:53 AM
airbusdrvr
Dec 27, 2015 07:43 PM
RossoDiamante
Track & Autocross
Sep 21, 2015 01:28 PM
Aniel
Sep 13, 2015 08:10 PM
