Tire wear Question
Old Jun 1, 2013 | 12:38 PM
bansasn's Avatar
bansasn is a name known to allbansasn is a name known to allbansasn is a name known to allbansasn is a name known to allbansasn is a name known to allbansasn is a name known to all
Tire wear Question
Gentlemen,
My rear tires has an even wear inner side wall. The front tires has no sign of wear what so ever. Is this normal? The tires are a 1 year old. My tire size are 285/35/22. I don't drive my vehicle hard. Normal most of the time.
Old Jun 1, 2013 | 05:04 PM
Dennis C's Avatar
This is normal. Do you rotate your tires regularly?
Old Jun 1, 2013 | 05:13 PM
bansasn's Avatar
Thanks for the replied. I have not rotate since I brought the tires new. That was a year ago. Is it wise to rotate the wore out rear tires to the front? Since the stopping power traction are from the front.
Old Jun 1, 2013 | 05:38 PM
Dennis C's Avatar
I suppose it depends on how worn they have become...
I try to rotate my tires every 5,000 miles. All Porsches (including Cayennes) are set up with negative camber in the rear suspension that leads to inner edge wear. It's one of the prices that you pay for performance. You can mitigate this wear issue by modifying the alignment settings, but you sacrifice performance when you do this. Your best bet is to rotate the tires frequently and accept the fact that they will wear quickly.
Old Jun 1, 2013 | 08:13 PM
bansasn's Avatar
Got it! Thanks for the suggestion.
Old Aug 18, 2013 | 09:51 PM
denversteve's Avatar
denversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond repute
No. It's wise to rotate the tires every 500-1,000 miles and you won't see any wear. Actually, the wear will be even. After a year, with visible wear, I would replace them and start with rotation monthly or every other month.
This should be done on every car but especially on Porsches and others that are known to eat through tires.
PAULUNM
14
May 27, 2016 06:54 AM
The_Ruski_Driver
Oct 25, 2015 08:40 PM
007AMV8
Oct 19, 2015 09:55 PM
Nikg
Sep 21, 2015 10:32 PM
horsepowerfarm
Sep 10, 2015 06:09 PM
