coolant level warning
Old Aug 2, 2013 | 07:29 AM
hadydaddy's Avatar
hadydaddy is infamous around these parts
in my part of the world temperature rises up-to 50c
i have experienced a coolant level warning but cars temperature stable, had it checked and topped up until the max level. will wait and see if it pops up again on the dash.
is this a symptom to a problem?
Old Aug 2, 2013 | 07:33 AM
Dennis C's Avatar
Have your coolant pipes been changed? If not, than this could be a slow leak from a cracked pipe. Once they start to leak, it isn't long before they fail. Another possibility is a water pump. They tend to leak a little bit prior to failure also.
What's the year and mileage of your Cayenne?
Old Aug 2, 2013 | 07:40 AM
hadydaddy's Avatar
its 2005
54680 mi
Old Aug 2, 2013 | 07:26 PM
Cpa4S's Avatar
Cpa4S is a splendid one to beholdCpa4S is a splendid one to beholdCpa4S is a splendid one to beholdCpa4S is a splendid one to beholdCpa4S is a splendid one to beholdCpa4S is a splendid one to beholdCpa4S is a splendid one to behold
by coolant signal - you mean the check engine light? i got that and the error code was coolant.
i'm a 2008 but still full warranty for a year.
Old Aug 3, 2013 | 07:08 AM
hadydaddy's Avatar
this is what appeared on my dial dash
Old Aug 3, 2013 | 07:40 AM
Dennis C's Avatar
Do you know if your coolant pipes have been changed?
Old Aug 3, 2013 | 07:44 AM
hadydaddy's Avatar
thats what i still have to find out
to do so i need to remove the intake manifold right?
airbusdrvr
Dec 27, 2015 07:43 PM
007 Vantage
Oct 8, 2015 08:35 PM
vogz
Oct 8, 2015 12:02 PM
BauerR
Sep 28, 2015 11:36 AM
Dan@AQS
Mid-Atlantic
Sep 26, 2015 06:04 PM
