Compression Loss/Engine Failure
Old Oct 29, 2013 | 09:36 AM
mx22's Avatar
mx22 is infamous around these parts
Originally Posted by nuttersandy
How can you over rev a cayenne on a downshift? Doesn't the computers prevent that from happening unless you have a manual?
But if I recall, there were no V8 manuals for the 955?
I was about to say that, how can you over-rev an auto transmission?
Old Oct 30, 2013 | 12:54 PM
DRYRUNNER's Avatar
DRYRUNNER is infamous around these parts
teenage drivers are the strongest people in the world, they can break anything...
Old Oct 30, 2013 | 12:57 PM
Renaissance.Man's Avatar
Moderator
Renaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond repute
Old Oct 30, 2013 | 01:09 PM
Vig03's Avatar
Vig03 is infamous around these parts
Has anyone else ever experienced on over-rev issue? I haven't come across this before...curious about how it happened
Old Oct 30, 2013 | 08:59 PM
Cole's Avatar
Cole is just really niceCole is just really niceCole is just really niceCole is just really nice
I'm curious how it happened. I've run my CTT on the track and it simply won't allow you to shift anytime the RPM would be too high.
Even in manual mode, it will upshift once the RPM is high enough in a straight line, it won't let you downshift unless the RPM is right. The only time it holds the rpm high is mid corner.
Old Oct 30, 2013 | 09:44 PM
Bigbuzuki's Avatar
Bigbuzuki is infamous around these parts
I suppose you can over rev if you select manual on the lever, and go down a steep hill.
Old Oct 30, 2013 | 09:49 PM
Cole's Avatar
It upshifts if the RPM gets too high, even in manual mode.
Old Nov 6, 2013 | 11:13 PM
gsieck's Avatar
gsieck is infamous around these parts
The final, final on this from my perspective: $13,000 to pull the motor, replace the valves, mill the heads. And there is no warranty on the work. Since it was unclear what actually caused the problem I am loathe to repair the existing motor.
So if you want a nice 2006 Cayenne Titanium S roller, make offer. The vehicle is at Sonnen Porsche, just outside of San Francisco.
pwdrhound
Sep 13, 2016 10:44 AM
DYL 911
Oct 1, 2015 02:47 PM
PelicanParts.com
Sep 25, 2015 03:17 PM
