Oil Change info
Old Dec 30, 2013 | 04:56 PM
JSavinoJr's Avatar
JSavinoJr has a spectacular aura aboutJSavinoJr has a spectacular aura aboutJSavinoJr has a spectacular aura about
Oil Change info
I do all the work on my 996. Got the 957 in August. I was just curious,How often is everyone changing their oil? How many quarts does the 08 Cayenne S take? And, Is everyone using 0w-40 ? Thanks again!
Old Dec 30, 2013 | 06:43 PM
elite1's Avatar
elite1 Is a GOD !elite1 Is a GOD !elite1 Is a GOD !elite1 Is a GOD !elite1 Is a GOD !elite1 Is a GOD !elite1 Is a GOD !elite1 Is a GOD !elite1 Is a GOD !elite1 Is a GOD !elite1 Is a GOD !
I used 8 qts. last time I did mine and used 0w40. You should also look into "Durametric" so you can reset you service light. Get the pro if you want to do coding.
Old Jan 3, 2014 | 06:51 PM
RushDL's Avatar
RushDL is infamous around these parts
on 955/Hi , its recommended 7K we all do a fraction of that I do 5K changes. Mobil-1 Synth 0-40 is correct. Spec is like 9.2 qts but it all wont all come out so plan on 9 with extra qt in the back. Use the stick to measure on level ground. It Should burn a quart between changes on MK-1 models. Believe it or not the light goes out after removing the oil cap.
Old Jan 3, 2014 | 07:16 PM
Bigbuzuki's Avatar
Bigbuzuki is infamous around these parts
Originally Posted by RushDL
.....Believe it or not the light goes out after removing the oil cap.
I don't believe it.
I believe it's when you pop the hood.
Old Jan 10, 2014 | 01:43 AM
waltertm's Avatar
waltertm is infamous around these parts
I change mine every 5k or 6 months whichever comes first. Some may think it's overkill but that's how I value my ride.
Old Jan 10, 2014 | 08:28 AM
Renaissance.Man's Avatar
Moderator
Renaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond repute
I just went through this with another member. Their website still has out dated information. You can do the coding with any version now. The only difference is the number of supported VINs
COBB Tuning
Jan 1, 2025 09:02 AM
SharkyShark20
Sep 19, 2015 09:54 PM
BLKonBLK911C4S
NorCal
Aug 29, 2015 03:20 AM
gulf gt
Aug 27, 2015 10:27 AM
00aston
Aug 27, 2015 12:01 AM
