Cayenne aftermarket Exhaust
Old Aug 13, 2014 | 01:11 PM
  #31
BamaScoot's Avatar
BamaScoot is infamous around these parts
Originally Posted by jdubbya
I'll have a magnaflow system installed on mine tomorrow evening. X-pipe, mufflers, new tips and all the install for less than $600. Was hoping to keep it under $500 but hadn't planned on the tips and X-pipe originally. After looking at how the stock tips are made I went with just a regular set of rolled edge dual tips. Can't wait to hear it uncorked!!
Does that include piping that deletes the secondary cats as well? I'm guessing crush bent?
Old Aug 13, 2014 | 01:24 PM
  #32
jdubbya's Avatar
jdubbya is a splendid one to beholdjdubbya is a splendid one to beholdjdubbya is a splendid one to beholdjdubbya is a splendid one to beholdjdubbya is a splendid one to beholdjdubbya is a splendid one to beholdjdubbya is a splendid one to behold
No that doesn't include bypass pipes. Pretty much the only pipes they will have to make at the local shop are elbows from each pipe into the mufflers and then out to the tips.
I'll look at adding bypass pipes later if I want a bit more power or sound!
Old Aug 13, 2014 | 01:35 PM
  #33
gh0stman's Avatar
gh0stman is infamous around these parts
Make sure they dont weld the joint up otherwise you will be in a world of hurt when you decide to change them out.
Old Aug 14, 2014 | 09:13 AM
  #34
jdubbya's Avatar
Will keep that in mind tonight. Can't believe how excited I am just hear a new exhaust! It's almost like Christmas!!
Old Aug 14, 2014 | 09:15 AM
  #35
gh0stman's Avatar
Post a video interested to hear it
Old Aug 14, 2014 | 09:26 AM
  #36
jdubbya's Avatar
Yeah I want to shoot a quick one before the install and after to compare.
Old Aug 14, 2014 | 11:44 PM
  #37
jdubbya's Avatar
Well that was an adventure. "Shouldn't take me more than an hour and a half".... three plus hours later...... I had time for a short drive and then home. I will say that so far I'm not totally thrilled with it. It does rumble a bit more at idle but I was expecting a little better sound. Not sure what it is I'm hearing at WOT though. It is louder but it almost sounds like a whistling noise. I need to get it warmed up and do some more driving to get a better sense of what it sounds like.
Old Aug 15, 2014 | 02:58 AM
  #38
gh0stman's Avatar
What variant do you have? You didnt happen to put a set of Whistle tips on it like Bubb Rubb and Lil Sis did you? lol
Old Aug 15, 2014 | 09:04 AM
  #39
jdubbya's Avatar
Ha, no I don't think so. It is a turbo so maybe I'm just not used to that sound yet? I know it won't sound like a big muscle car but I was expecting a bit more rumble especially on start up. I park in a large garage for work and it sounded bouncing off the ramp walls but I think I'm on my way to cat bypass pipes before long.
I forgot to get a video of before but I'll get an after posted this weekend!
Old Aug 15, 2014 | 09:07 AM
  #40
BamaScoot's Avatar
Is the whistling from the exhaust or intake? If you have evoms it may be from those. If it's from exhaust I'd suspect a small exhaust leak in one of the welds.
Old Aug 15, 2014 | 11:03 AM
  #41
Waitin4Dv's Avatar
Waitin4Dv is infamous around these parts
I did the bypass pipes left stock exhaust and happy. Probably won't get exhaust. I know allot of guys just did bypass and got the sound they wanted.
Old Aug 15, 2014 | 03:49 PM
  #42
jdubbya's Avatar
No, defintely from the exhaust and I'm pretty sure the intake is all stock. It's actually more of a whoosh than a whistle but it seemed to be mainly on the passenger side which is what struck me as odd. I need to drive it some more and see what happens.
Yeah I kept the stock exhaust although it must weight 75-80+ lbs, I can't imagine putting it back on. I'll look at ordering bypass pipes soon, at least that should be a pretty simple DIY job.
Old Aug 18, 2014 | 08:50 AM
  #43
jdubbya's Avatar
Quick update. The more I drive it the less it seems to whistle. I think it is really just an overlap in one of the joints somewhere. I'm going to take the tips off and drive it to see if it is in the tips or the pipes. Not nearly as bad as it was the first night though. Still not very loud though so I am looking at bypass pipes.
Old Aug 18, 2014 | 12:23 PM
  #44
TSAF NKUF's Avatar
TSAF NKUF is infamous around these parts
I'm kinda curious to know what flowmaster or spintech mufflers would sound like on one of these things.
Old Aug 18, 2014 | 12:28 PM
  #45
gh0stman's Avatar
Im sure the Flowmasters would give it a deep growl.
