Which rotors and pads should I get?
Old Mar 31, 2014 | 06:22 PM
BobbySpeed's Avatar
BobbySpeed is infamous around these partsBobbySpeed is infamous around these parts
My warning light will be coming on soon because My front brakes will need to be changed.
OEM, Zimmerman, EBC, or a different brand for rotors? Drilled, slotted?
OEM, Pagid, Hawk HPS, Hawk ceramic, or different brand pads?
Naturally I would like less dust, but most importantly I want better braking.
What have you tried and liked and feel comfortable recommending?
Old Apr 6, 2014 | 10:17 PM
BobbySpeed's Avatar
Nobody has an opinion on how well their brakes work?
Old Apr 7, 2014 | 07:06 AM
mrbrianc's Avatar
mrbrianc is just really nicemrbrianc is just really nicemrbrianc is just really nicemrbrianc is just really nice
I use EBC Reds Ceramic on the CTTS & Hawk Performance Ceramic on the CS - Way Less Brake dust. Pads & rotors last much longer than OEM, but if you track, then not as good of a performance option as OEM. On the street though you will not feel any difference in performance (at least I didn't).
Old Apr 7, 2014 | 01:10 PM
Renaissance.Man's Avatar
Moderator
Renaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond repute
I think a search will yield information that is also applicable.
Old Apr 7, 2014 | 04:15 PM
JSavinoJr's Avatar
JSavinoJr has a spectacular aura aboutJSavinoJr has a spectacular aura aboutJSavinoJr has a spectacular aura about
I just put on the EBC'S. Huge difference in brake dust. Haven't noticed much on the performance end. I just do light street driving.
Old Apr 12, 2014 | 06:01 AM
duh's Avatar
duh
duh is infamous around these parts
I went with powerstop to try them out. The rotors are actually ebc (stamped), the pads have been great so far, no complaints yet. For 350 or so for all four corners, it was worth a try and ive been happy.
Old Apr 29, 2014 | 12:29 PM
4x4's Avatar
4x4
4x4 is infamous around these parts
I got Brembo rotors and Textar pads with ATE sensors for my 957 Turbo. Havent changed them yet, will let you know how they are once I have them replaced.
Old May 6, 2014 | 03:22 PM
blah1's Avatar
blah1 is infamous around these parts
As mrbrianc stated, performance wise, OEM will be your best option as far as pads go. Usually with "less dust" pads, the initial coefficient of friction is lower and personally, on the street, I would want as much initial braking performance since you never know when you need to all of a sudden slam on the brakes. However, if less dust is a major priority, than I'm sure what the others have been using are great. BTW, Pagid is the OEM supplier if I am not mistaken.
As far as rotors, anything cheap should suffice as long as they can with stand the heat as well as OEM. For more performance oriented rotors, I would suggest slotted as they keep the surface contact between the pads and the rotors clean, as a result the initial bite is kept to a maximum. Never been a fan of cross drilled due to cracking, but that's only if you are seriously running hard or tracking the vehicle. Cross drilled are purely cosmetic. If you want to get fancy, 2-pc rotors save weight, and less weight equates to more power.
Like Renaissance.Man said, the search button is your best friend.
my_tom_a
Sep 28, 2015 09:01 PM
albert@velosdesignwerks
American Muscle Vendor Classifieds
Sep 9, 2015 04:21 PM
Other British Cars
Sep 9, 2015 04:18 PM
Sep 9, 2015 04:17 PM
GT3/GT2/GT Vendor Classifieds
Sep 9, 2015 03:55 PM
