09 CTT - NGK Iridium spark plugs?
Old Apr 12, 2014 | 08:58 PM
DirtyVegas's Avatar
DirtyVegas has much to be proud ofDirtyVegas has much to be proud ofDirtyVegas has much to be proud ofDirtyVegas has much to be proud ofDirtyVegas has much to be proud ofDirtyVegas has much to be proud ofDirtyVegas has much to be proud ofDirtyVegas has much to be proud of
I was told that I may need a colder spark plug to run with higher boost on 91. Does anyone know if these will work in the CTT?
http://www.ngk.com/product.aspx?zpid=9352
Old Apr 14, 2014 | 10:55 AM
Renaissance.Man's Avatar
Moderator
Renaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond repute
I am running about the highest level of boost that these TD04 are good for.. I am on the edges of the compressor map at 16.8 psi. I ran colder plugs, but went back to OEM with no issues. Are you sure you need colder plugs? What boost level are you trying to run?
Old Apr 14, 2014 | 06:33 PM
DirtyVegas's Avatar
Thanks for your reply. Got a tune, and car chokes/hesitates around 3.5K range. I was told that I should give colder spark plugs a try since I'm at a high altitude with 91 gas. I realize that stock plugs work for many with mods, but I have heard of them to be a culprit in some issues when running higher than normal boost (below). I also had a few shops tell me the same that are in Southwest including Vivid, so I figured I'd ask...
https://www.6speedonline.com/forums/...ng-issues.html
https://www.6speedonline.com/forums/...r-woke-up.html
Old Apr 14, 2014 | 06:36 PM
Moderator
These are the colder plugs I ran.. they worked great for me while they were installed.
Denso IK22
https://www.6speedonline.com/forums/...ml#post3623021
EDIT: If you are having hesitation issues, you may want to shorten the spark plug gap to around 0.6mm to see if it smooths out the power delivery
rzmnco
Cayenne 955/957
Oct 7, 2025 03:12 PM
laz74
Oct 2, 2015 06:08 AM
Boltons991qtr
Sep 20, 2015 06:57 PM
jungt
Sep 16, 2015 05:28 AM
