Custom Brake Conversion for 957 CTT
Old May 9, 2014 | 09:25 AM
  #31
Serg124's Avatar
Serg124 has a reputation beyond reputeSerg124 has a reputation beyond reputeSerg124 has a reputation beyond reputeSerg124 has a reputation beyond reputeSerg124 has a reputation beyond reputeSerg124 has a reputation beyond reputeSerg124 has a reputation beyond reputeSerg124 has a reputation beyond reputeSerg124 has a reputation beyond reputeSerg124 has a reputation beyond reputeSerg124 has a reputation beyond repute
Same
Old May 13, 2014 | 02:19 PM
  #32
liam_b's Avatar
liam_b is infamous around these parts
If you want to know what stock brakes were/are fitted to a particular Cayenne use the PR codes from the build sticker from under the rear floor or the service booklet.
My 2009 turboS has stock brakes, front brakes PR code 1LH are 380mm, rear brakes PR code 1KP are 358mm with newer style caliper which requires removal to access pads.
Locate the brake PR codes from your build sticker, you can look up the PR codes available in the 9PA1 parts catalog from Porsche.com
Old Jun 4, 2014 | 02:14 AM
  #33
Serg124's Avatar
Originally Posted by TT VIPER
315's in the front? Hell, yeah. )) You got to learn me the width and offset of that wheel? There is no way ET 50 will work in the front. Maybe they are ET 40 or lower.
back to the question. 11J R23 ET50
ID:	382562   Click image for larger version
ID:	382563   Click image for larger version
ID:	382564   Click image for larger version
ID:	382565   Click image for larger version
Old Jun 9, 2014 | 12:54 PM
  #34
jdubbya's Avatar
jdubbya is a splendid one to beholdjdubbya is a splendid one to beholdjdubbya is a splendid one to beholdjdubbya is a splendid one to beholdjdubbya is a splendid one to beholdjdubbya is a splendid one to beholdjdubbya is a splendid one to behold
Good info. Seems there were a lot of variations based on model and options. My 2005 CTT has the iE81 option and came with 380mm front and 355mm rear.
Are your front rotors two piece?
Jul 29, 2019 11:13 AM
97GtsMonster
Nov 17, 2015 12:38 PM
AJUSA.com
997 Vendor Classifieds
Oct 8, 2015 05:50 PM
Sales@RSW
BMW //M
Aug 26, 2015 06:41 AM
The Oss
Aug 24, 2015 08:19 PM
