Serpentine belt replacement diy?
Old Dec 1, 2014 | 12:16 PM
pwdrhound's Avatar
Anyone have a DIY for a serpentine belt replacement?
Old Dec 1, 2014 | 04:52 PM
jdubbya's Avatar
jdubbya is a splendid one to beholdjdubbya is a splendid one to beholdjdubbya is a splendid one to beholdjdubbya is a splendid one to beholdjdubbya is a splendid one to beholdjdubbya is a splendid one to beholdjdubbya is a splendid one to behold
Here you go. I will be taking this on myself before too long!
http://www.pelicanparts.com/techarti...eplacement.htm
Old Dec 1, 2014 | 09:58 PM
jdubbya's Avatar
There is also a better DIY post on Renntech if you are a member there. It goes into more detail for the Turbo. Unfortunately it shows removing more stuff in order to get at the belt and the various pulleys.
Old Dec 2, 2014 | 11:08 PM
elite1's Avatar
elite1 Is a GOD !elite1 Is a GOD !elite1 Is a GOD !elite1 Is a GOD !elite1 Is a GOD !elite1 Is a GOD !elite1 Is a GOD !elite1 Is a GOD !elite1 Is a GOD !elite1 Is a GOD !elite1 Is a GOD !
Dude, let me know when you do it! I did mine 3 weeks ago. Along with a bunch of other unnecessary things.
Old Dec 3, 2014 | 03:32 AM
gh0stman's Avatar
gh0stman is infamous around these parts
30mm wrench, dang that's huge. Guess its time to go any check mine out.
Old Dec 3, 2014 | 07:14 AM
elite1's Avatar
It's a 6 sided bolt. I used a large cresent wrench.
Old Dec 3, 2014 | 07:31 AM
pwdrhound's Avatar
Sweet. I'll order the belt and let's knock it out one weekend.
Old Aug 22, 2022 | 02:57 PM
Corvetteboy6988's Avatar
5 Year Member
Corvetteboy6988 is infamous around these parts
Does anyone have the link to the turbo belt change mentioned, Im really struggling with mine and might have to give up and take to the indy.
Old Aug 23, 2022 | 01:54 PM
5 Year Member
Nevermind, I found it:
https://www.renntech.org/tutorials/a.../?_fromLogin=1
i attempted to do the belt, but I couldnt get the small hard vac line going to the turbo/diverter valve disconnected, nor the larger EGR/vent tube that needed disconnected on the turbos to get them to pass through the belt, not enough room to get a good pull on them, dont think it was the squeeze connectors themselves, rather the fittings seem welded together, they wouldnt budge or I would have to break them, which would be a lot more effort on my part and cost. Not sure how you get a wrench on the adjuster nut to take the slack off either without getting that EGR pipe disconnected and removed out of the way. I could get the top end disconnected, but not the bottom end by the pulleys.
I contemplated cutting at least the smaller turbo/diverter feed hard line and replacing a section with a soft vac line and clamps. Cant really do the same for the larger EGR tube, I guess you could with larger hose. Guess Im gonna leave it to an Indy or dealer to try, and if they break the lines its on them, not me, lol.
audipwr1
Sep 25, 2021 01:31 PM
The Oss
Aug 24, 2015 08:19 PM
Lucid Moment
Aug 20, 2015 02:22 PM
