Replacing turbo without removing engine
SubscribeMy turbo housing on the drivers side turbo is cracked. The cheapest quote to repair it was over $6k, due to the fact that all the mechanics are unanimous in saying the engine needs to be dropped out to replace it. I decided to try myself to replace it without dropping the engine.
I have all of the turbo disconnected and all bolts out except 1 pipe which is preventing the turbo coming out - the one beneath the turbo. Any ideas how to undo this while the engine is still in the car?
Alternatively I am thinking of cutting this bottom metal (coolant?) pipe and making a joint or union. This would make it far easier to remove the old turbo and install the new one. Question is, what kind of union is available to make a good, re-connectable joint here?
Well, I cut the pipe and freed the turbo, but it does not fit through any gap to get it out of the engine bay...
Quote:
Well that sucks. Was hoping you'd figured it out. Can you make enough room by loosening the motor mount and lifting the motor up just a bit maybe?
I did exactly that, and I also removed parts from the turbo. Old turbo is out, new one is in place and I am halfway through hooking up all the hoses and pipes. It has not been an easy job.
I can imagine. There isn't much room in there at all. I had a car I had to do that just to get the starter out. Replaced it with a gear reduction starter, MUCH smaller and easier to get back in.
Just goes to prove, where there's a will, there's a way!!
