05 Cayenne S engine woes....engine cut out.
Old Oct 20, 2020 | 08:42 PM
Zuffenhausen955's Avatar
Zuffenhausen955 is infamous around these partsZuffenhausen955 is infamous around these parts
Originally Posted by paulwu
Thanks for the input. I just got the car back from a dealer mechanic and confirmed to be stretched camshaft chain at bank 1 and big job. Guess is the time to put it to sleep, only 230k Kms crazy!
Find an independent who can do it. Engine removal not necessary. When done - enjoy another 250km!
Old Dec 17, 2020 | 09:31 PM
Bigbuzuki's Avatar
Bigbuzuki is infamous around these parts
A suspect crankshaft sensor can also cause issues. Cheap enough to replace.
Has your chain been definitely confirmed that it is stretched?
If it hasn’t jumped a tooth then do the following before drinking the Kool Aid and replacing the timing chain.
Replace your timing chain tensioner, along with the top 2 chain guides and the 2 cam timing solenoids which can be done with the cam covers removed.
Get the cams retimed whilst your there and your problem will be solved.
divaka
Cayenne 955/957
Apr 26, 2015 08:17 PM
pwdrhound
Cayenne 955/957
Nov 23, 2014 10:29 PM
kkswow12
Jul 14, 2014 05:31 AM
av996tt
Mar 15, 2014 11:27 AM
Zippy
Aug 21, 2012 06:00 PM
