CTT front airshock mount bushing & upper control arms replacement
Old Nov 1, 2016 | 10:15 PM
ciaka's Avatar
If you notice your car is squeaking a lot at front, not smooth over bumps, has noises coming out of front, chances are your shock mount bushings are damaged and need replacement.
If you need to do this, I hope you can use this tutorial to get it all fixed. Hope it helps. Feel free to give feedback afterwards. Thank you.
Pics labeled *-DRV are for driver side shock...otherwise everything else is same on both sides. It is Pics 18 and 19.
Old Nov 1, 2016 | 10:16 PM
ciaka's Avatar
more pics...
Old Dec 4, 2019 | 04:10 AM
LukasM's Avatar
LukasM is infamous around these parts
Thank you so much for the detailed tutorial, very helpful!!
How much would you estimate does this take per side if you have all the proper tools and parts ready to go?
Cheers,
Lukas
Old Dec 4, 2019 | 06:57 AM
ciaka's Avatar
If you have never removed shocks or control arms in the Cayenne, I would expect you will take about 6 hours per side (remove shock, replace bushing, reassemble back into place). I would plan to do this over weekend, making sure you have the genuine replacement parts, tools, then take your time.
If you have already done this before, time would be about 2 or 3 hours per side total.
Cheers,
Lukas
Old Dec 5, 2019 | 03:17 AM
LukasM's Avatar
Thanks for the estimate ciaka, this gives me a good idea what I'll have to deal with.
Appreciate the reply!
Best regards from Austria,
Lukas
ciaka
Jun 14, 2018 09:14 PM
dynoguy
Cayenne 955/957
Mar 4, 2017 06:49 AM
2002sheds
Mar 8, 2016 08:26 AM
Chi-town
Dec 12, 2015 09:06 AM
pumalex
Aug 13, 2011 06:54 PM
