Max tire size off road Caynee
Old 01-15-2019, 06:39 PM
Larporsche's Avatar
Larporsche is an unknown quantity at this point
Question Max tire size off road Caynee
Hello I have a 2004 Porsche Caynee with spring suspension 18 inch wheels I’m looking to know the largest size off road tire I can put on safely without it rubbing
i am seeing all kinds of info but not a definite answer I do not have air suspension will a 265/65/18 fit or is there another option thank you
Old 09-16-2022, 05:39 AM
spacemonkey957's Avatar
spacemonkey957 is an unknown quantity at this point
bumping this thread because I cannot for the life of me find this information! I have a base 957 with steel springs as well. Car came with 19" wheels, but I picked up the 18" transsyberia wheels off eBay recently. Hoping to run 265/65/18, I wouldn't mind the 255/55/18 size, but would like my build to run what the transsyberia cars did. I just don't know if air suspension is necessary. everyone who's shared it works have a turbo model and air suspension hahaha
Old 09-17-2022, 06:04 PM
Rvca3112's Avatar
Rvca3112 has a brilliant futureRvca3112 has a brilliant futureRvca3112 has a brilliant futureRvca3112 has a brilliant futureRvca3112 has a brilliant futureRvca3112 has a brilliant futureRvca3112 has a brilliant futureRvca3112 has a brilliant futureRvca3112 has a brilliant futureRvca3112 has a brilliant futureRvca3112 has a brilliant future
You can run an265/65/18 with minimal rubbing. A 2.5 inch lift and 1 inch subframe drop will benefit you from the larger tires but you’ll still rub on the fender liners a bit. You can either trim the lower valence off the truck or heat up the wheel wells and massage then inward
here’s my truck
Old 12-01-2022, 06:12 AM
smi2710's Avatar
smi2710 is an unknown quantity at this point
on the 955 from the info i gathered ( i just picked up a 05 S) and i decided to go with 265/60/18 as it is not a trail rig and from everything i have seen you can run the 265/65/18's on the 955 with no issue since it has bigger fender wells then the 957 but your on road driving experience will be a bit different with the 65's as opposed to the 60's
Old 12-14-2022, 02:21 PM
jriggs's Avatar
jriggs is on a distinguished road
This like chart Mike over at Eurowise made should be helpful
Larporsche
Cayenne
01-15-2019 06:43 PM
rabbit1445
07-27-2015 01:29 AM
regrossman
09-02-2011 10:22 PM
empire0007
911
04-10-2011 12:03 AM
ceddy
09-19-2005 07:06 AM
Quick Reply: Max tire size off road Caynee
