New battery
Old Apr 27, 2019 | 04:37 PM
NJ99's Avatar
NJ99 is infamous around these parts
New battery
How long do batteries tend to last. I have a 2016 base Cayenne and am bringing my car in for its three year service (about two months late) and was wondering whether it makes sense to do a preventive change of battery. I understand the battery is under the front seat? If it does die, would AAA be able to change it or jump it?
Old Apr 27, 2019 | 05:10 PM
mto's Avatar
mto
mto has much to be proud ofmto has much to be proud ofmto has much to be proud ofmto has much to be proud ofmto has much to be proud ofmto has much to be proud ofmto has much to be proud ofmto has much to be proud ofmto has much to be proud of
It varies. Short drives, all highway, when car not in use if was on battery tender, weather conditions, batteries hate extreme heat. That said, I change batteries in my cars every 3 to 4 years. You may get another year or more, but to me is rather cheap insurance to replace.
No way AAA can replace the battery, imo. Sure they can jump it with owner manual instructions, It is not done on the battery. I found it easiest to remove my battery by removing the seat, even though it is not necessary. Took about one hour. Actually pretty easy dyi.
Old Apr 27, 2019 | 11:36 PM
racer_65's Avatar
racer_65 is infamous around these parts
Follow the instructions here:
https://www.pelicanparts.com/techart...eplacement.htm
You need two less common tools: 10 mm XZN bolt, and a T25 Torx screw.
Ciamaichelo
Sep 14, 2012 07:28 PM
S-351
19
May 1, 2011 09:19 AM
