Easy entry seats and trunk locking - '05 CTT
Old May 23, 2019 | 09:49 AM
ciaka's Avatar
Anyone know where I should start looking to fix 2 things? It is for my 2005 CTT.
1. Easy entry driver seat - mine no longer moves automatically back/forward when i enter car. Move manually with switches. Steering wheel still moves automatically though when entering/exiting car.
2. Car trunk lid wont unlock unless I open back doors first. That is, unlocked parked car, you can open trunk any time. IF i start car, drive, then park, open door and try open trunk, it wont, until i open any back door, then trunk is unlocked.
Anyone has ideas, I will greatly appreciate it.
Old Jun 2, 2019 | 08:55 AM
LanceGT4's Avatar
5 Year Member
LanceGT4 is infamous around these parts
You could check your doors and confirm that all of them turn the dome lights on. I noticed that I had some of your symptoms and my drivers door and right rear door did not turn on the lights. After replacing the drivers door latch the autolock and unlock started working again. If a door doesn't trigger the door open signals some functions seems to have issues.
Old Jun 3, 2019 | 07:58 PM
toby.yeung's Avatar
toby.yeung is infamous around these parts
It may worth it to ensure the trunk top window is closed and locked firmly. Some kind of weird symptoms appearing eg. alerts, lights & locks will want your attention, it doesn't do what it should be doing. It happened to mine once, it took me a while to sort this out. Lucky I didn't take action to visit the mechanic so early. Other area could be fuses but I am not qualified or experience enough to offer comments...
Good luck!
Old Jun 10, 2019 | 06:25 AM
ciaka's Avatar
Curiously I checked the door lights (ones that are on the doors themselves, red, light up when you open door). The driver door light is out. I will see if it is the bulb, and go from there.
Can you tell me what door latch you replaced? Are you talking about the entire door lock mechanism?
Do you have pricing for parts you replaced? Time involvement? Thank you.
Old Jun 15, 2019 | 05:05 PM
LanceGT4's Avatar
5 Year Member
I'm not sure if the door lights are on the same data path as the door open sensors. I replaced the drivers door latch. There is a micro switch that triggers on door open. it was about $200 from Pelican. It wasn't worth taking the door apart and not doing a full replacement. The process is a little fiddly but someone did a good writeup on RennTech.org you can search for.
tshaw
Bentley
Feb 19, 2019 04:10 PM
ciaka
Cayenne
Jan 1, 2019 06:43 AM
CY00
Cayenne 955/957
Jan 21, 2018 03:56 AM
fixedupw203
Jun 2, 2013 10:39 AM
fixedupw203
Apr 25, 2013 06:31 PM
