Anyone replace coolant vent line (y tubs?) with heater hose?
Old Apr 22, 2020 | 12:04 AM
ciaka's Avatar
That y tube is so very brittle, that every time you work on the area, you are virtually guaranteed to break it in some way.
I am thinking, put a connector tube into the heater hose at the back, clamp, put another heater hose of fitting diameter, on other end of the plastic tube, clamp again, and the other end of the heater hose, plug pon top of prepared ending of the y pipe (pre cut before the split, so that the heater hose is a straight line). This will at least keep the back end of the pipe more resistant to heat. At some point I may think of something to refit the connectors to each bank too.
Just throwing this out for yall to advise me on. Thanks.
03 996tt
Nov 7, 2014 10:37 PM
bmwtmx
Dec 30, 2013 09:09 AM
TimAZ
Oct 5, 2013 09:41 PM
Glacier
Jun 27, 2011 01:27 PM
N1_kT
Dec 2, 2008 12:06 PM
