957 std exhaust Q
Old Feb 25, 2021 | 12:12 PM
zagamuffin's Avatar
zagamuffin is infamous around these parts
957 std exhaust Q
Hi all,
bought a base cayenne and it needs a bit of work, one thing I’ve done already is change out the two sports cans on the back for a std turbo S Backbox as it was too loud for my wife.it quieted it a little but not enough, it really rasps Badley when accelerating so I’m wondering if it should have a center box as well.it’S a duel pipe system so not sure if I should add a center silencer ??
Old Feb 26, 2021 | 04:33 AM
zagamuffin's Avatar
Anyone with a 3.6 that can answer please ?
Old Mar 10, 2021 | 08:43 PM
Rvca3112's Avatar
Rvca3112 has a brilliant futureRvca3112 has a brilliant futureRvca3112 has a brilliant futureRvca3112 has a brilliant futureRvca3112 has a brilliant futureRvca3112 has a brilliant futureRvca3112 has a brilliant futureRvca3112 has a brilliant futureRvca3112 has a brilliant futureRvca3112 has a brilliant futureRvca3112 has a brilliant future
Do you have cat bypass pipes also? There is not a middle resonator on the cayenne. There is a primary cat, a secondary cat which acts like a resonator but I think they’re too small to be classified as one. Then lastly there is the rear muffler. Maybe put the stock system back on?
Old Mar 10, 2021 | 11:15 PM
zagamuffin's Avatar
Tks for the reply
all cats in place , bought it with aftermarket and removed, fitted with std Porsche rear suitcase and still silly loud .might pull it to check if it’s bypassed internally so , good to know it didn’t come with a center box tho
Old Mar 11, 2021 | 06:52 AM
Rvca3112's Avatar
More than likely somethings not right. Check the flex pipes on the primary cats. They do tend to crack with some miles. Your car should be relatively quiet
Old Mar 23, 2021 | 11:06 AM
zagamuffin's Avatar
I checked the flex is and in good nick, Tks for the suggestion.I’d say at this stage it’s a modified Backbox and as the systems about ten pieces badley welded together I picked up a completely std 4.5vi8 system and will swap that over. Will report back....
CTT9060
Cayenne Turbo
Nov 25, 2016 10:02 AM
Aussie
Cayenne 955/957
Apr 6, 2013 06:57 PM
Proximo
Cayenne 955/957
45
Aug 1, 2011 06:22 PM
Matrix
Cayenne 955/957
Jul 20, 2010 11:55 AM
ehaser1
Cayenne 955/957
Jan 8, 2007 01:19 PM
