Cardan shaft issues again.
Old Jun 27, 2021 | 02:03 AM
Sparkysi's Avatar
Sparkysi is infamous around these parts
Hi all! I am really hoping someone can help before I pull my hair out. I Have a 955 Cayenne S and under hard acceleration I was getting a thumping through the centre armrest. Sure enough the rubber bushing around the centre support bearing had failed, I replaced the entire shaft with a brand new GKN shaft. However I still have the same thumping through the centre armrest. What could it be? Bad shaft? Any advice and help would be greatly appreciated.
Old Jul 4, 2021 | 09:06 AM
Blubayou's Avatar
Blubayou is infamous around these parts
Good morning Sparkysi, I'm assuming you haven't put many miles on your Cayenne since the new shaft. If that's the case it's likely a defective shaft/center bearing. Did you verify it was the center bearing support that has failed? Call the manufacturer and report a warranty claim. It happens, bet your installation will be much quicker this time. Cheers!
Old Jul 4, 2021 | 04:48 PM
Sparkysi's Avatar
Hi and thanks for your reply. I ended up returning the shaft as after inspection once I removed it again there was play in the splines and the rubber in the bearing carrier was really soft. Replaced the shaft with a new one and problem solved. Thanks again. Simon
Yotam Refael
Cayenne 955/957
Jul 29, 2015 07:31 AM
Yotam Refael
Jul 27, 2015 01:38 PM
bmbratz
Cayenne 955/957
May 18, 2013 08:48 PM
steve harris
Cayenne
Oct 3, 2012 07:38 AM
Hassankarim
Apr 19, 2012 05:53 AM
