My car has the shakes!
Hey guys I have CTT 06 whenever I hit the brakes to slowdown from approx 120 kmph (75mph) the steering wheel vibrates like crazy..it starts out as a mild vibration, over time it becomes unbearable. Sent it to the dealers, they say the rotors get distorted due to the heat ( I live in the Oman ) and the heat caused by using the brakes..The dealer has changed the rotors twice under warranty and the shakes go away but seem to return after a few months. I do not push the car unusually hard.. as in I don't drive like a maniac.
How can the rotors last for such a short time? do any of you guys have the same problem?
Sounds like warped rotors .. are you sure they are changing them? They might be keeping them on and just straightening them. Also, check the balance/alignment of the wheels. If that still doesn't fix the issue, look into a aftermarket brake kit (stoptech / brembo)
8000 miles on mine with wife driving.Not a problem.Also alot of spirited driving with me behind the wheel in the mountains.
great point they may be just turning them down.This would make them thinner and heat up faster.Had a gmc dealer do this once on my yukon.Ended up being the "idiot"on showroom floor yelling.Truck had 5000 miles with town driving by my wife.They told me it was normal But I would check to see if they replaced or turn the rotors and if it was all or one or just front or back.
Might be a result of living in an extremely hot environment accopmanied by spirited driving...
Make sure you dont wash your car without letting it cool down as the cool wather might warp the rotors?
Mine is squeeky once in a while due to brake dust but never vibrates...
Have you checked the wheels as well? Might be a front rim warp..
Thanks for the feedback all. Just gave the service manager an earful. He said there might be rust on the brakes disks .. regardless the retards should have caught that while they were "replacing the rotors" I suspect they didnt change jack the last two times I complained. Should have asked them to bag the parts, serves me right to trust a dealership to do the right thing.
Not buying any comments about extremely hot climate and warping - I do however suggest an alignment check and balnce check of your wheels.
PorscheEnthusiast
11-13-2015 02:23 PM
r_matt_6
10-08-2015 06:07 PM
