lowering links?
Old Jan 12, 2007 | 12:21 AM
ehaser1's Avatar
ehaser1 is infamous around these parts
lowering links?
I have a rinspeed lowering module that my dealer refuses to install because they dont want to cut the wires.
should i buy a plug and play module or get lowering links??
has anyone heard of these??
http://www.adjustableairride.com/
Old Jan 12, 2007 | 01:42 AM
alex911s's Avatar
alex911s has a reputation beyond reputealex911s has a reputation beyond reputealex911s has a reputation beyond reputealex911s has a reputation beyond reputealex911s has a reputation beyond reputealex911s has a reputation beyond reputealex911s has a reputation beyond reputealex911s has a reputation beyond reputealex911s has a reputation beyond reputealex911s has a reputation beyond reputealex911s has a reputation beyond repute
hmmm cut wires? how much you want
I'm pretty sure it's the same module as Cargraphic..hmmm
Old Jan 12, 2007 | 04:44 AM
turbo'S''s Avatar
turbo'S' is infamous around these parts
Adjustable ride
I have just fitted a set of links yesterday to my CTT and although my first attempt has set the car too low, I believe they will work a treat. I need to shorten the link length as my first attempt dropped it down to what would be loading level which is just too low for me. Took 30 mins tops to fit and I dont think it will take long to adjust. Will take pics when I adjust it but hope the rain stops here to let me do it!
Old Jan 12, 2007 | 09:06 AM
ehaser1's Avatar
Rinspeed module
if anyone wants my rinspeed module im looking for 800bucks..
Old Jan 12, 2007 | 03:16 PM
ammo_collector's Avatar
ammo_collector is infamous around these parts
How was your ride quality affected with the lowering links? Bouncy? Harsh? I have 20" sport technos on my CT, want to lower it, but not willing to comprimise ride quality. Also, when hitting the mountain, I'm worried about ground clearance. With the links, can you still go to terrain height?
Old Jan 12, 2007 | 07:18 PM
SMR's Avatar
SMR
SMR is a jewel in the roughSMR is a jewel in the roughSMR is a jewel in the roughSMR is a jewel in the rough
pictures please
Old Jan 13, 2007 | 05:12 AM
turbo'S''s Avatar
I have not had the time to raise them yet but with it very low the ride quality is much harsher on my 22" wheels. I will hopefully get the time today to raise it and see what its like mid way. It is currently about 80mm lower than standard which I think looks cool but wont work comfortably. The terrain level is brought down the same amount so if you do any offroading this is not the answer and the electronic method would be the better one.
Old Jan 14, 2007 | 09:27 AM
Cognac's Avatar
Cognac has a brilliant futureCognac has a brilliant futureCognac has a brilliant futureCognac has a brilliant futureCognac has a brilliant futureCognac has a brilliant futureCognac has a brilliant futureCognac has a brilliant futureCognac has a brilliant futureCognac has a brilliant futureCognac has a brilliant future
imo, try to set at 40mm drop.
i have discussed this over 10 times with 9ff in germany.
i dropped my car below loading level and was tooo bouncy.
i felt like i was in a lowrider...
it feels solid and perfect @ 40mm drop.
my links are set @ +- 4mm per twist.
however, i would say electric module is the best.
Old Jan 14, 2007 | 10:17 AM
SMR's Avatar
SMR
Why would elektrikal modul be better, if you never riser or lower your car...
Old Jan 14, 2007 | 10:19 AM
Cognac's Avatar
it's pre-programmed.
plus, you don't have go through with over 20 emails unless you get a gurantee height from company...
Old Jan 14, 2007 | 10:33 AM
SMR's Avatar
SMR
Understand but 9ff sucks so that i could have told you before..
Im going lowering links when i get my CTT
Old Jan 14, 2007 | 10:48 AM
Cognac's Avatar
i didn't say they(9ff) were the best...
height of suspension was my biggest concern.
i didn't want to ruin my brand new toy cause of few hundred $$$ part.
however, i wanted to take different route and got what i want it.
plus, no one had it in this forum.
i just had try a new product and report back to my family.
yeah, so far so good.
again try to get an ideal height without hurting your suspension.
pasm is not cheap...
Old Jan 14, 2007 | 01:48 PM
SMR's Avatar
SMR
I dont se the problem...
I do want to lower the car but will never use the hight adjusment, so for me a fixed ride hight is okey...why should i pay 2000 dollar for something i dont need
Old Jan 15, 2007 | 09:42 AM
SMR's Avatar
SMR
Links orderd now....
DLF
Cayenne 955/957
10
Feb 28, 2022 11:49 PM
Rockinc1
Sep 30, 2015 06:44 PM
proTUNING Freaks
Sep 15, 2015 07:28 AM
