how to hardwire a radar detector?
Old Jan 22, 2007 | 05:36 PM
kdubb's Avatar
kdubb is infamous around these parts
anyone done it in their CTT?
whats the easiest/best way ??
Old Jan 22, 2007 | 08:43 PM
BobbySpeed's Avatar
BobbySpeed is infamous around these partsBobbySpeed is infamous around these parts
My Valentine 1 is hardwired to the homelink- you just need to tap into a powered line. It's a 15 minute install if you are handy.
Old Jan 22, 2007 | 08:46 PM
kdubb's Avatar
is there a "how-to" on this ?
Old Jan 22, 2007 | 08:50 PM
BobbySpeed's Avatar
There is one on renntech- it's really easy, and it looks good.
Good luck!
Old Jan 28, 2007 | 10:15 AM
BLTZKRG's Avatar
BLTZKRG is infamous around these parts
My Cars an 04 CTT, no homelink! I just mounted my Valentine 1 on the screen, then ran the long cable up the rain sensor tube, along the inside of the screen, down the screen pillar, I used a credit card to stuff the cable under the headliner and under the side moulding of the screen pillar. When I got to the base of the pillar I just ran it along the top past the speaker grille again pushing it under the trim with the CC and looped it around and into the fuse box on the outside of the dashboard. Once you pull off the cover there you have access to the fusebox, seemed OK to me.
Now just find a spare fuse that's wired to the ignition.
If you'd like I'll post some pics
Old Jan 28, 2007 | 10:21 AM
detailersdomain's Avatar
detailersdomain has a reputation beyond reputedetailersdomain has a reputation beyond reputedetailersdomain has a reputation beyond reputedetailersdomain has a reputation beyond reputedetailersdomain has a reputation beyond reputedetailersdomain has a reputation beyond reputedetailersdomain has a reputation beyond reputedetailersdomain has a reputation beyond reputedetailersdomain has a reputation beyond reputedetailersdomain has a reputation beyond reputedetailersdomain has a reputation beyond repute
Please post some pics of the install.
Thanks!
Old Jan 28, 2007 | 11:10 AM
SpeedDemon's Avatar
SpeedDemon is infamous around these parts
if you go to the drivers side fuse box i believe fuse 41 is ignition switched thats where my V1 is connected to..yes renntech.org has a how to.
Old Jan 28, 2007 | 11:25 AM
BLTZKRG's Avatar
I'll take some pics later today and post them
Old Jan 28, 2007 | 12:06 PM
porschespeeddemon's Avatar
porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !
I've installed several Passport SRX's on Cayennes, I wouldn't recommend this for the novice DIY'er but when done right, looks very professional and works great. This system uses the license plate frame mounted one in the rear, a radar sensor in front, and 2 laser diffusers in front, this is also more expensive than the V1 though.
Old Jan 28, 2007 | 01:08 PM
kdubb's Avatar
cant wait
Old Jan 28, 2007 | 05:29 PM
BobbySpeed's Avatar
That's a definite go- I went to the Homelink because I have it, and it's so darn close.
Old Jan 28, 2007 | 06:12 PM
SpeedDemon's Avatar
Thanks for the backup bobbyspeed
Old Jan 28, 2007 | 11:55 PM
BobbySpeed's Avatar
You're welcome- always looking to help and learn from a friend!
Personally, I used 41 for my Motorola bluetooth kit and mounted it in the same spot as Kooser- love the pics on his web site!
Old Jan 29, 2007 | 01:29 PM
SpeedDemon's Avatar
yea koosers got great ideas...yes i did the same with my IHF 1000 where did you put the pod mines on the right of the steering wheel..does kosser have pics of the ihf1000 location?
Old Jan 29, 2007 | 05:34 PM
BobbySpeed's Avatar
I have the Moto controller above my light switch, the mic to the right of my gauges, and the CDR23 integrated for the speaker.
As you can see, my Valentine 1 is hardwired to my homelink.
Sorry, the car really needs to be cleaned, and I have not been up to the task latley.
