LED bulbs in rear license plate lights?
Old Jan 29, 2007 | 04:50 AM
thsiao's Avatar
thsiao is just really nicethsiao is just really nicethsiao is just really nicethsiao is just really nicethsiao is just really nice
Question LED bulbs in rear license plate lights?
So I got a pair of LED bulbs for the rear license plate lights and this is what happened. When I have BOTH LED bulbs installed at the same time, the bulbs don't work and I get the warning signal at the dash. However, if I replace one of the LED bulbs with a regular one (meaning I have 1 LED and 1 normal on the car), both connect bulbs work perfectly. WTF? Works when I have one of each but won't work when I have both LED bulbs connected...
Here are the bulbs I got http://www.eautoworks.com/html/ORD-1-1-1-22502.cfm
Old Jan 29, 2007 | 08:28 AM
mudman2's Avatar
mudman2 is infamous around these parts
You are underestimating the level of detail in the self test diagnostics on the Cayenne. The impedance of LED lighting is different from regular bulbs, 2 obviously puts it out of acceptable range.
Old Jan 29, 2007 | 09:43 AM
BD 997's Avatar
BD 997 is infamous around these parts
LED use less power so the car thinks the regular bulbs are out....
Old Jan 29, 2007 | 01:31 PM
SpeedDemon's Avatar
SpeedDemon is infamous around these parts
how do they look ? besides the error
Old Jan 29, 2007 | 01:46 PM
thsiao's Avatar
They look really nice...
So anyone has LEDs on the rear license plates?
Old Jan 29, 2007 | 02:05 PM
XLR82XS's Avatar
I do. Red. They look great. No warning indicators though, thank god.
Old Jan 29, 2007 | 02:35 PM
Frisco's Avatar
Senior Member
Frisco is infamous around these parts
you can probably fake out the sensor by adding an appropriately sized resistor in series
Old Jan 29, 2007 | 04:32 PM
SpeedDemon's Avatar
i want to order the ones you have in blue should i jsut order them and give it a shot?
Old Jan 30, 2007 | 05:22 PM
thsiao's Avatar
Got a reply from the store saying that I need a load resistor... so instead of going through all that hassle, I'm just gonna replace them with white bulbs.
Thinking of getting these: http://www.eautoworks.com/html/ORD-1-1-1-2067.cfm
However, I noticed that the wattage on these bulbs are 10W while the OEM stock one is 5W. Is this safe? Will the connector burn/melt because of the higher wattage? Please advice. Thank you.
COBB Tuning
Jan 1, 2025 09:02 AM
TrackOne
Aug 20, 2015 12:56 PM
Jeff1smith
Aug 19, 2015 09:41 PM
