TPMS in 22's
Old Apr 4, 2007 | 07:45 AM
wheels's Avatar
wheels is infamous around these parts
TPMS in 22's
Is anyone using 22 inch wheels with TPMS? Which wheel/tire size did you input when programming the system? Since 22's are not an option in the system I used the 275/40x20. I'm getting a lot more low pressure warnings then with the stock tires. Maybe I'm running too close to the low end of the pressure limit. What tire pressure do you guys recommend with 285/35x22?
Sorry for all the questions at one time!
Old Apr 4, 2007 | 08:36 AM
damon@tirerack's Avatar
Moderator
22" wheels for what?
damon@tirerack.com
877-522-8473 ext. 4643
574-287-2345 ext. 4643
Or use this link:
Old Apr 4, 2007 | 08:44 AM
wheels's Avatar
Sorry! 22" Techarts mounted on 2006 Cayenne Turbo S. 285/35R22 Michelin Diamaris from Tire Rack of course.
Old Apr 4, 2007 | 09:54 AM
BD 997's Avatar
BD 997 is infamous around these parts
what happens to TPMS if you put on wheels with no sensors? Any warnings come on?
Old Apr 4, 2007 | 01:25 PM
wheels's Avatar
Sorry BD 977, can't answer that one. I put the sensors in the Techarts right from the start. But as I was trying to program the TPMS I did notice you can turn it off. I would assume if you mount tires without TPMS you just turn the system off.
Old Apr 4, 2007 | 05:46 PM
BD 997's Avatar
good info... thanks!
Old Apr 5, 2007 | 02:29 AM
emissary's Avatar
emissary is infamous around these parts
I have TPMS sensors on my 22-inch wheels. If the TPMS system is active and sensors are not present on your wheels, you will receive an error message (complete with loud beeps) after approximately five minutes of driving. You can turn the TPMS system off, although you will always get a "TPMS" system off warning (with no beep I believe) when you start the car.
In terms of configuring the TPMS system for use with 22s, I selected the largest wheel/tire size the computer had available. I believe the pressure readings read about 2psi lower than actual values.
Obviously, the real value of the TPMS system is that it lets you know when you have critical pressure loss, which may be difficult to visually see given the low tire profile and stiff sidewalls of tires on 22-inch wheels. It definitely works...don't ask me how I know that...
In terms of recommended tire pressures, I believe I was running 42psi front and 48psi rear last summer for my 295/35-22 tires (truth be told, I'm still on winter wheels/tires...I haven't put the summer tires back on yet).
Old Apr 11, 2007 | 05:12 PM
G_A's Avatar
G_A
G_A is a glorious beacon of lightG_A is a glorious beacon of lightG_A is a glorious beacon of lightG_A is a glorious beacon of lightG_A is a glorious beacon of lightG_A is a glorious beacon of light
Yes! I did it!
Good news! Dealer can programm wheels for 2006- TPMS with system tester. after you can select 22s in cluster menu. but do you know correct pressure for your tires? dealer should enter figures during programming - for FA/RA and part/full load.
need4speedmotors
996 Turbo Vendor Classifieds
Jan 12, 2016 05:41 PM
C5tt
Oct 24, 2015 07:35 PM
freddiemac
Oct 7, 2015 11:05 AM
miken168
Oct 6, 2015 09:21 AM
need4speedmotors
997 Turbo Vendor Classifieds
Sep 28, 2015 04:47 PM
