Fuse - keeps blowing
Old Apr 7, 2007 | 10:31 PM
HawkDucati's Avatar
HawkDucati is infamous around these parts
Hi Folks - My power sockets quit working so I took a look at the #1 20amp fuse and sure enough, it had popped. I removed and replaced with one of the 20amp spares and it popped right as I pushed it in. Ignition was off, key was out and nothing was plugged into the sockets. Any ideas before I take it in and waste a couple of hours at the dealership?
'05 Cayenne S
Old Apr 11, 2007 | 05:41 PM
G_A's Avatar
G_A
G_A is a glorious beacon of lightG_A is a glorious beacon of lightG_A is a glorious beacon of lightG_A is a glorious beacon of lightG_A is a glorious beacon of lightG_A is a glorious beacon of light
not depend from key
power always present on sockets. check all of them - 2 or 3 at front, 1 or 2 @ rear console and 1 or 2 @ trunk - put some in out few times witout fuse inserted. I think one of them broken, can easy fix youself, or simple disconnect bad one.
Regards
Alex.
Old Apr 11, 2007 | 06:46 PM
5speed's Avatar
5speed is infamous around these parts
Check all of the sockets carefully. I have come across more than one where a coin was in the bottom of the socket causing a dead short.
Old Apr 11, 2007 | 07:03 PM
Gramicci101's Avatar
Gramicci101 Is a GOD !Gramicci101 Is a GOD !Gramicci101 Is a GOD !Gramicci101 Is a GOD !Gramicci101 Is a GOD !Gramicci101 Is a GOD !Gramicci101 Is a GOD !Gramicci101 Is a GOD !Gramicci101 Is a GOD !Gramicci101 Is a GOD !Gramicci101 Is a GOD !
5speed is right. There is a short somewhere in your electrical system. That kind of thing should be covered by warranty. Make sure nothing is wedged in the sockets, and then take it in. Isolating a short in a complex system is a long, frustrating, fury-inducing process; let someone else do it.
adnanm3
Oct 25, 2016 08:38 AM
airbusdrvr
Dec 27, 2015 07:43 PM
gliozzi
Bentley
Sep 29, 2015 09:27 AM
gliozzi
Bentley
Sep 28, 2015 03:27 PM
