Panoramic Roof and Wind Noise
Old Feb 22, 2014 | 07:16 AM
wrinkledpants's Avatar
wrinkledpants is infamous around these parts
Do you 955 guys with the pano roof still have the tracks in the roof where the load carry bars are supposed to go?
Old Dec 12, 2016 | 09:38 PM
Zuffenhausen955's Avatar
Zuffenhausen955 is infamous around these partsZuffenhausen955 is infamous around these parts
The front rubber weatherstripping may "lift" at speeds exceeding 90mph, resulting in noise. Continuing to drive this fast will make the weatherstrip peel-away at the front corners, flapping at the front. The solution is to clean the plastic channel the rubber tucks into with alcohol, use a Torx T25 driver and loosen the front rails. Lift the front rails and use a body trim-specific plastic spatula and tuck-in the rubber sides and corners. Apply a bead of Shoe Goo inside the plastic channel the stripping and push the loose stripping and set it to cure with blue Painter's tape for 48 hours.
Bmw M3 Guy
Feb 21, 2018 09:29 AM
NorthWiking
Sep 21, 2015 02:22 PM
JSF721
Detailing
Sep 8, 2015 07:57 AM
