Key remote battery
Old Aug 8, 2007 | 09:47 AM
pigcorn's Avatar
pigcorn is infamous around these parts
Key remote battery
I put my key in the ignition and the dash gave a fault saying they key battery is low. I looked the battery fob quickly and have no idea how to open it to see what battery is inside??
Any idea on how to replace the key fob battery?
Old Aug 8, 2007 | 09:52 AM
codey's Avatar
codey is infamous around these parts
just pull the back off. open the key up and tug at the bottom part of the back of the key...under the porsche symbol...it will pop off
Old Aug 8, 2007 | 09:55 AM
pigcorn's Avatar
Thanks will do.
Old Jan 17, 2009 | 02:44 PM
gixxer1127's Avatar
gixxer1127 is infamous around these parts
im trying to figure out how to change it also. both my keys are now at low battery
Old Jan 17, 2009 | 06:45 PM
wwjd's Avatar
wwjd is infamous around these parts
my key had same problem and I took both keys to the service, they gave two new ones.
I think the battery should be charged during driving.
Old Jan 17, 2009 | 10:21 PM
canberk's Avatar
canberk is infamous around these parts
there is no such thing as charging the battery while driving. The only battery that gets charged while driving is your car's main battery
get some CR2016 batteries for your remotes, you should be all set..
Old Jan 18, 2009 | 08:40 AM
wwjd's Avatar
my audi serviceman told me that key battery would be charged when insert the key, i thought they both are basically the same thing.
but i'm not sure
Old Jan 18, 2009 | 07:32 PM
canberk's Avatar
first of all, those lithium CR2016 batteries are not rechargeable. If your dealer believes so, then ask for whole remote replacements every time you run out of battery, telling them that there should be a problem with the remote itself. Other than that, seriously, your car does not charge your remote batteries at any time It does charge the main battery that your vehicle uses to start up the engine and for other stuff though..
Old Jan 18, 2009 | 08:40 PM
gixxer1127's Avatar
can anyone give some insight and guidance on how to open the key up?
Old Jan 18, 2009 | 08:44 PM
huskyfan23's Avatar
huskyfan23 is infamous around these parts
See the seam separating the upper half from the lower half? The lower portion is the battery cover.
Flip open the key and pull that panel off.
Old Jan 18, 2009 | 09:18 PM
gixxer1127's Avatar
Thanks!!
Old Jan 18, 2009 | 11:19 PM
CayenneS's Avatar
CayenneS is infamous around these parts
Take the fob key to any watch repair shop
they have the cr2016
make sure the battery is Sony or Panasonic batteries, they would last longer..
Old Aug 17, 2013 | 08:57 PM
spawnywhippet's Avatar
spawnywhippet has a spectacular aura aboutspawnywhippet has a spectacular aura aboutspawnywhippet has a spectacular aura about
The car can *never* charge your fob battery, there is no charging mechanism in the fob and it uses non-rechargeable CR2016, (although I just checked my 2005 Cayenne Turbo batteries which were not operating too well and it has a CR2032 installed).
Old Aug 17, 2013 | 09:02 PM
denversteve's Avatar
denversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond repute
Yep. Insert it into the ignition switch, turn to the right and release. Then drive to the dealership......... they'll do it for you in about 5 minutes......... while you look at the cars on the showroom floor. It's not worth the time to play with it, drive to the store anyway and do it yourself.
Old Aug 17, 2013 | 09:03 PM
Try that and let us know how it works for you.
NC 996TT
Mar 23, 2023 06:19 AM
pwdrhound
Sep 13, 2016 10:44 AM
lokmeup
Sep 9, 2015 09:24 PM
ECS Tuning - VW
Sep 8, 2015 12:54 PM
