Need Wheel Spacer Advice...
Old Nov 3, 2011 | 03:30 PM
Vinnysca's Avatar
Vinnysca is a splendid one to beholdVinnysca is a splendid one to beholdVinnysca is a splendid one to beholdVinnysca is a splendid one to beholdVinnysca is a splendid one to beholdVinnysca is a splendid one to beholdVinnysca is a splendid one to behold
Smile Need Wheel Spacer Advice...
Hey guys,
I just received new wheels/tires for my Cayenne S today. They are OEM 21 inch GTS wheels which I found on eBay a couple days ago. I tried fitting one front wheel onto the car, and realized that I need spacers since the wheel is in contact with the brake caliper.
Any advice on what kind of wheel spacers are best?
Thank you so much!
Vinny
Old Nov 4, 2011 | 12:58 AM
Ylincooper's Avatar
Ylincooper is infamous around these parts
Porsche offers 17mm spacers I'm sure you can get at the dealer. Otherwise just see if H&R or Hubcentric has any made for the cayenne.
Ylincooper's Avatar
Post pics when they're on btw! Those wheels are sexy!
Old Nov 4, 2011 | 03:45 AM
V10M's Avatar
V10M is infamous around these parts
The overall diameter of the wheel looks much bigger than stock. What is the tire size of the 21" wheel?
Old Nov 4, 2011 | 05:17 AM
Vinnysca's Avatar
They are 295 / 35 / 21 Michelins.
Vinny
Old Nov 4, 2011 | 10:05 AM
Vinnysca's Avatar
Originally Posted by Wheel Enhancement
We sent you a PM but did not hear back from you. Please call us at 310-836-8908 in regards to your fitment issue.
Thanks,
John P. Brown
Wheel Enhancement
I will call you today after work.
Vinny
Old Nov 4, 2011 | 05:24 PM
Vinnysca's Avatar
Thanks,
John P. Brown
Wheel Enhancement
Thanks for the reply. I decided to use H & R spacers.
Cheers,
Vinny
Old Nov 4, 2011 | 05:31 PM
Vinnysca's Avatar
Update:
I decided to fit the GTS wheels in the rears of my Cayenne S. I didn't need any spacers for the rears at all. The calipers are clearing the inside of the wheels and the tires are flush with the rear wheel arch.
I then decided to remove my Carrera S' front H & R spacers (7mm) and try it on my Cayenne. The wheel bolt patterns are exactly the same in the Cayenne's and it did stick out a bit more than the rears. So I purchased a 5 mm spacer as I have a feeling that it'll be just enough to make the wheel clear the calipers and make the tires not stick out as much.
Vinny
Old Nov 4, 2011 | 07:58 PM
j080808's Avatar
j080808 is infamous around these parts
Looks great! 10x21 with a 50 offset, that is the same spec as SportEdition or Turbo II wheels. I would have thought they would fit without rubbing too...
Old Nov 4, 2011 | 11:48 PM
Ylincooper's Avatar
Very nice! Lets get some better pics up!
Old Nov 5, 2011 | 09:21 AM
damon@tirerack's Avatar
Moderator
Good job Vinny. The cars all use the 5 x 130 bolt circle. 7 and 15mm are most popular.
I do have both in stock from H&R if interested as well as the longer bolts. The 15mm are piloted for the wheel and the 7mm is not.
damon@tirerack.com
877-522-8473 ext. 4643
574-287-2345 ext. 4643
Or use this link:
Old Jul 22, 2014 | 05:34 AM
boxs1's Avatar
boxs1 is infamous around these parts
What Piloted means ?
PelicanParts.com
930 Turbo Vendor Classifieds
Aug 18, 2015 04:01 PM
PelicanParts.com
964
Aug 18, 2015 03:57 PM
PelicanParts.com
964 Turbo
Aug 18, 2015 03:56 PM
PelicanParts.com
Aug 18, 2015 03:51 PM
PelicanParts.com
GT3/GT2/GT Vendor Classifieds
Aug 18, 2015 03:42 PM
