Sound system glitch when playing CDs
Old Jan 12, 2012 | 06:39 AM
The Big Easy's Avatar
The Big Easy has a spectacular aura aboutThe Big Easy has a spectacular aura aboutThe Big Easy has a spectacular aura about
Hi Guys,
Having a problem when playing CDs through the Burmeister system - the sound goes away for a split second and then returns. This happens infrequently/completely at random/cant be replicated, but is rather annoying. It especially happens when using the forward button to go to the next track - almost sounds as if the CD gets stuck for a millisecond......
Any comments/suggestions would be appreciated.
Seasons greetings to all!
Cheers,
Old Jan 12, 2012 | 07:26 AM
finiteyoda's Avatar
finiteyoda is infamous around these parts
I've started noticing a similar issue playing music thru bluetooth, I wonder if it's not the CD player, but just the stereo itself. Could be maybe an amp clipping issue? You could maybe ask your dealer, I have a feeling debugging this problem's gonna be tricky, since it'll be difficult to isolate what system is causing it.
Old Jan 12, 2012 | 09:07 AM
jesh's Avatar
jesh is infamous around these parts
I have this happen randomly with bluetooth iPhone and also through wired iPod I could see this happening with bluetooth, but with the wired iPod it is throwing me off.
Old Jan 12, 2012 | 11:50 AM
DanK's Avatar
DanK is infamous around these parts
happens to me too with both wired ipod and bluetooth iphone 4. always happens after I come to a stop...
Old Jan 12, 2012 | 01:07 PM
Ptarded's Avatar
Ptarded is a jewel in the roughPtarded is a jewel in the roughPtarded is a jewel in the rough
Same any ideas would be appreciated. My dealer said they'd have to keep the car to replicate the problem. Don't really feel like leavin it at the dealers do they can not figure anything out and I'm in a crappy loaner. The problem became more and more frequent as time went on. I unplugged it and plugged it back in and the problem stopped and hasn't come back for a few days, well see. Seems like it might be a software issue if that's the case.
Old Jan 13, 2012 | 12:56 AM
I dont seem to have a problem when the iPOD is connected directly - interesting to hear that you seem to be experiencing this. I found that if you like to skim through CDs while searching for your favorite track, it may cause it to occur more often or when the outside temperature > 25 degrees celcius - becomes more frequent.
Dealer has taken the unit out, checked connections, software checked.
Cheers,
Old Jan 13, 2012 | 11:12 AM
Ptarded's Avatar
Interesting, also I'm using the Bose system. At least its not isolated to one system, a more widespread problem could find a solution faster. Never use CD's so I can't comment on its functionality.
audipwr1
Sep 25, 2021 01:31 PM
Superaudiofreak
Jun 10, 2016 02:04 PM
pshep138
Sep 1, 2015 09:45 AM
orbelo
Aug 30, 2015 12:26 PM
