Had Fuel Tank Sensor Changed
Old Sep 14, 2012 | 07:56 AM
Moss1st's Avatar
Moss1st is infamous around these parts
Exclamation Had Fuel Tank Sensor Changed
Hello,
Had my dealer replace one of the fuel tank sensors after it malfunctioned. It was covered under warranty. The car drove fine all the way back to home. I tried to start the engine after a while but it wouldn't. And right after the ignition stops, fuel starts spilling out of the fuel tank.
Any thoughts on what could be causing all this?
Best,
Moss
Old Sep 14, 2012 | 10:07 AM
steph280's Avatar
steph280 has a spectacular aura aboutsteph280 has a spectacular aura about
Sorry to hear about your problem. But what prompt the replacement in the first place? Did you get an error on the MFD?
I got a fuel sensor malfunction error on the MFD after filling up once, but it went away after a while and hasn't came back. Wondering if it's something to be concerned about.
Old Sep 14, 2012 | 10:24 AM
Moss1st's Avatar
The check engine light came up a few times between fill-ups. It showed in the vehicle computer history that it was caused by one fuel tank sensor malfunction. That's what prompted the replacement.
Old Sep 22, 2012 | 11:34 PM
Moss1st's Avatar
Thumbs up Problem Solved
A hose that directs fuel from the tank to the engine had a broken plastic clipse. The hose is located under the rear right passenger seat. The clipse has been replaced and the car now runs perfectly!
J9277655
Dec 28, 2015 11:01 PM
97GtsMonster
Nov 17, 2015 12:38 PM
turbotuner20v
Sep 11, 2015 12:02 PM
LiquidElephant
Aug 27, 2015 06:17 PM
00aston
Aug 27, 2015 12:01 AM
