Installed my Valentine 1 Easily for 958 2011 and On
Old Jan 15, 2013 | 01:47 PM
Aperture776's Avatar
Aperture776 is infamous around these parts
Thanks for the info. Like some have asked, could you please post some pictures of the installation. I would love to do this as well.
Old Jan 16, 2013 | 06:41 PM
gnat's Avatar
gnat has a brilliant futuregnat has a brilliant futuregnat has a brilliant futuregnat has a brilliant futuregnat has a brilliant futuregnat has a brilliant futuregnat has a brilliant futuregnat has a brilliant futuregnat has a brilliant futuregnat has a brilliant futuregnat has a brilliant future
Slightly off topic, but here are some pics of the solution I'm working on for the remote display.
I noticed that the RD was a nearly perfect width/height/depth match for the upper area of the non-smokers pocket in front of the shifter. A bit of cutting and grinding later and I think I have a winner in progress.
It's kind of hard to tell in the relevant pictures, but basically a hole about the size of the display was cut on on the front and rear and the display was slid through. I'm not sure it was needed, but it's tacked in place with a bit of glue.
Now I need to pull the center console apart to run the cable.
Old May 25, 2014 | 12:10 AM
mprsev's Avatar
mprsev is infamous around these partsmprsev is infamous around these parts
Sorry to revive an old thread but I could not figure out which wire was the power as I found a couple wires with blue stripes but none were solid blue.
Old May 26, 2014 | 07:10 AM
wpgfordguy's Avatar
wpgfordguy Is a GOD !wpgfordguy Is a GOD !wpgfordguy Is a GOD !wpgfordguy Is a GOD !wpgfordguy Is a GOD !wpgfordguy Is a GOD !wpgfordguy Is a GOD !wpgfordguy Is a GOD !wpgfordguy Is a GOD !wpgfordguy Is a GOD !wpgfordguy Is a GOD !
for what it's worth I use a Blendmount and a Mirror tap, have had on the last 5 cars. "Matt Approved"
Old May 26, 2014 | 08:23 AM
OCNYPORSCHE's Avatar
OCNYPORSCHE has a spectacular aura aboutOCNYPORSCHE has a spectacular aura aboutOCNYPORSCHE has a spectacular aura about
I did this a while back. I think as long as the blue is with the brown wire, then its the right blue. Just take a voltmeter and test it when you turn car on and then off.
Old May 26, 2014 | 03:01 PM
BlazinPond's Avatar
BlazinPond has much to be proud ofBlazinPond has much to be proud ofBlazinPond has much to be proud ofBlazinPond has much to be proud ofBlazinPond has much to be proud ofBlazinPond has much to be proud ofBlazinPond has much to be proud ofBlazinPond has much to be proud ofBlazinPond has much to be proud of
Great to know - thanks for posting. I have the direct wire cord for my Escort but haven't attempted install yet.
I'm thrilled to know that i should be able to tap into the rearview mirror.
Old May 26, 2014 | 04:38 PM
visitador's Avatar
visitador is infamous around these partsvisitador is infamous around these parts
I hope I am not hijacking this thread too much. Anyone with adaptive cruise control has issues with their radar detector? I think you, Gnat, have adaptive cruise control, right?
Old May 26, 2014 | 05:37 PM
gnat's Avatar
Nope, I didn't want that kind of stuff
I haven't heard complaints about that feature causing issues if it's your car (some makes will trigger it if you get near another car with it on though), but I have heard people with the heated windshield and/or LCA complain about it. Do you have either of those?
Old May 26, 2014 | 05:54 PM
visitador's Avatar
Not heated windshield but LCA (it is part of the package). I guess I'll keep obeying the law, then.
Old May 26, 2014 | 08:03 PM
gnat's Avatar
You might try disabling LCA for a bit (is there a button or do you have to pull the fuse?) and see if that clears up your issues.
You might also reach out to Mike Valentine and see if he has any suggestions. I've found Mike to be an extremely personable and helpful guy.
You should also check your Serial Number and see if there have been upgrades since your's was built. An upgrade might have a fix already.
Ummm... Yeah.... I always follow the posted speed limit... Yeah. That's it!
2lflat4
Nov 18, 2019 05:05 PM
The_Ruski_Driver
Oct 25, 2015 08:40 PM
turbotuner20v
Sep 11, 2015 12:02 PM
o'bluetouring
Cayenne 958
Aug 24, 2015 01:17 PM
carrera4slakem
Aug 20, 2015 11:36 PM
You have already rated this thread Rating: Thread Rating: 3 votes, 5.00 average.
