Cayenne 2013 Spacers!?
Old Dec 4, 2012 | 06:01 PM
ld100's Avatar
ld100 is infamous around these parts
Can someone explain to me how to measure offset for wheel spacers?
I have 13 Cayenne with 20" Spider wheels and would like to add spacers. Not sure how to measure properly and what to get. Any help greatly appreciated!
Any pictures if anyone had it done?
Old Dec 5, 2012 | 12:55 AM
Harry Da Hamster's Avatar
Harry Da Hamster has much to be proud ofHarry Da Hamster has much to be proud ofHarry Da Hamster has much to be proud ofHarry Da Hamster has much to be proud ofHarry Da Hamster has much to be proud ofHarry Da Hamster has much to be proud ofHarry Da Hamster has much to be proud ofHarry Da Hamster has much to be proud ofHarry Da Hamster has much to be proud ofHarry Da Hamster has much to be proud of
I never measured the Cayenne for spacers but you can use the same technique i used for my M3. Get a piece of string 1' long, tape, a quarter, and a ruler. Tape one end of the string to the quarter and tape the other end to the top edge of the fender. Use the ruler to measure the wheel inset at its top edge. You should be able to get a good idea of what sized spacers to use from here.
An example. My M3 has a 29mm wheel inset in front and a 14mm wheel inset in back. I got a 25mm spacer for the front and 10mm spacer for the rear to give it that aggressive stance.
Old Dec 5, 2012 | 07:16 PM
j080808's Avatar
j080808 is infamous around these parts
Here is some reference including some pics with my 20" Spyder wheels. They are for sale as well.
https://www.6speedonline.com/forums/...m-spacers.html
DLF
Cayenne 955/957
10
Feb 28, 2022 11:49 PM
dgreen78
Feb 29, 2016 11:28 PM
Rockinc1
Sep 30, 2015 06:44 PM
