Footwell lighting strange behavior
Old Feb 27, 2013 | 08:14 PM
ACar's Avatar
ACar is infamous around these parts
The LEDs for the footwell are dimmable like OEM lights.
For glove box, footwell, door = T10 5 SMD 194 wedge type will work
For cargo overhead = Dome 41mm 12 SMD type would do, or a 9 SMD if you like it less bright. I use 12 SMD. This comes on only when you lift the tailgate or open/close doors.
For license plate = error free T10 5 SMD 194
Best is to get a few extras as they are very cheap on eBay.
Note that you may see a little blue spots shining on the footwell. I think this is due to the White LEd passing through the lens of the footwell. I don't find it a unpleasant at all.
Old Feb 28, 2013 | 09:49 PM
LGPM's Avatar
LGPM is infamous around these parts
thanks for your help
thank you
Old Mar 23, 2013 | 06:25 AM
TGED's Avatar
TGED is infamous around these parts
ACar, do you have any problem installing the rear footwell lights, I was not able to remove the housing of both rear footwell lights. Somehow they are different from the front ones which there was no problem to remove. Any help is appreciated.
J9277655
Dec 28, 2015 11:01 PM
GSR Autosport
Aug 26, 2015 05:20 PM
